best audio connection from dvd
soundfreak1
Best audio sound from dvd, optical out , coaxial, or use the 5 ch.audio outs. Just courious if there is any audible diff. Equip. Used; demon 1940 ci into a b& k ref. 30 ( if this matters) driven by 5 ch. SS high current PA 2200 HK amp. Thanks in advance.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Optical and digital coax should sound the same. Analog may sound different. Only your ears can tell which you'll like better.
Digital connections are the best unless you plan on using a SACD player. If you use the analog connections,you will drop all the processing the B&K offers because it only does it in the digital domain.HT SYSTEM-
lsi 9's -
Thanks, this sys. Is a dedacated HT no music i have 2 ch. Analog for that. Thought the optical would be beat thqnks for the comformation.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
You decided not to sell the b&k?Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
I switched from Digital coax to Optical and could tell a difference immediately. But really, it's like mdaudioguy said, "only your ears can tell which you like better".Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier -
Which did your ears prefer Mr. Sharpe? Coax or Optical?
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Optical. but to be totally honest that going from a crap cable from WalMart to Monster... soooo obviously anything is better than a Walmart brand lolHome theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Yes, to get an "equal" audio output signal, you should be using equivalent wire. That said, even the quality of the optical and coax jacks can have an effect.
Greg
I don't get why he uses both the denon and the ref 30. The b&k is light years better than the denon and he has a 5 channel amp. Digital connection from dvd into the Ref 30 , connect the amp and your off to the races.HT SYSTEM-
lsi 9's -
The Denon 1940 is his DVD player
Ah..doh...gotcha. Slow tonight.
lsi 9's -
post 14 reported for clicky link in sig.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
they're getting good at deleting spam messages before I even see them... that's good. I hate spam. it's annoying.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
