FXi A6 vs Energy's CR-10
Babber
Babber Posts: 31
edited July 2011 in Speakers
Hi all,
Contemplating between Polk's FXi A6 or Energy's CR-10 for side surrounds. I currently have RTi A3's for front, CSi A6 for Centre, and RTi A1's for rears.
Would the CR-10's fit in with this setup or should I go with the FXi A6's?
If I stay with FXi A6 it's obviously timbre matched to the rest of my system but would it make that much of a difference if I went with Energy's speakers?
The pro's of the Energy's are they are smaller and would fit where I need to mount them better than the FXi's but I still could mount the FXi's. Both have diople vs biople switches.
Anyone have experience with the Energy's?
Thanks,
Babber
Home Theatre
Receiver: Onkyo TX-NR808
Fronts: RTi A3
Centre: CSi A6
Sides: FXi A6
Rears: OWM 5
Subwoofer: TBD
Post edited by Babber on
  • codyc1ark
    codyc1ark Posts: 2,539
    edited July 2011
    I haven't heard either speaker, but I'd say this really has to do with the 'what if' factor. I'd stay with the Polks because you'll never ask yourself 'what if' I had gone with the Polks for matching surrounds. Plus you'll have matching speakers all around, sound and looks. Just my .02, good luck.
    EndersShadow Posts: 17,722
    edited July 2011
    You dont need to timbre match surrounds to your mains. The only exceptions I can think of would be going from Horn's to Dome tweeters. That might create a bit of a problem IMHO.
    But not a problem in this case. So use whatever suits ya best and ENJOY!
  • Babber
    Babber Posts: 31
    edited July 2011
    Thanks for the input. Decisions, decisions....
    Home Theatre
    Fronts: RTi A3
    Centre: CSi A6
    Sides: FXi A6
    Rears: OWM 5
    Subwoofer: TBD
  • gfong
    gfong Posts: 1,079
    edited July 2011
    DSkip wrote: »
    If space is an issue, why not look at the FXi-A4? I have the older version (FX300i) and love them. They are also quite a bit smaller than the bigger brothers.
    I second this good mans advice. I had the 4's and upgraded to the 6's and did not believe the size difference.
    The A4's sound great by the way, they are no slouch.
