Pair of Peerless Tweeters for Monitor 7
saemark30
Any Peerless tweeter from Monitor 7,10,12 should fit.
Post edited by saemark30 on
There was one on ebay a day or two ago but they go pretty quick.Check it out.
There is a Peerless clone on Ebay.
I wonder if that sounds the same as the original? -
Probably not, the long time members recommend the rdo194s I think that's as close as you will get . Or take your time and some peerless, they do come up every once in a while on ebay.Another way would be to find a set of beat up 5s 7s or 10 with peerless tweeters cheap. I picked up my last pair of 7bs for 40.00.http://cgi.ebay.com/NOS-POLK-PEERLESS-SILK-DOME-TWEETER-STEREO-SPEAKER-/250855667863?pt=Vintage_Electronics_R2&hash=item3a6829b897 or http://cgi.ebay.com/Polk-Monitor-Bookshelf-Speakers-VINTAGE-/170669514622?pt=Vintage_Electronics_R2&hash=item27bcb21f7e With the set of 5s you could flip the drivers and pay for your tweeters.Just a thought. Dan
I should have a pair of Peerless Denmark in an average pair of Model 5.
I'll pull them to be sure they're Denmark. I haven't pulled them in a while and not 100% sure which pair of 5s they're in. -
There is a Peerless USA tweeter version as well. I'm not an expert so I don't know which one sounds better/smoother.
You do realize the peerless and sl2000 and rdo are not interchangable? The x-overs are different for the peerless and they are physically smaller than the other 2. Does your M7 currently use peereless or are you looking for an alternative to the sl2000 because the RD0's in Canada are too expensive?
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
