Monitor 70 vs. Series II vs Tsi400
bfor916
bfor916 Posts: 2
edited July 2011 in Speakers
Hi everyone! This is my first post after reading a lot on this forum and am currently trying to figure out what speakers I need. I am a college student and primarily use my speakers for music at house parties and need a system that wont blow out. I listen to everything from classic rock to hip hop with the occasional movie thrown in. Going to be using a Yamaha RX-V371 receiever and buying refurb directly through polk. I need help finding out what the best bang for my buck will be on a set of speakers.
1. Monitor 70s $380
2. Tsi400 $380
3. Monitor 70 Series II $400
Thanks for the future input
Post edited by bfor916 on
    tonyb Posts: 33,068
    edited July 2011
    House parties, college, equates to loud volumes. Your better off with pa speakers that are more suited for such. A cheap receiver at loud volumes will give out enough distortion to say bye-bye to the Polks. Before we go there though, maybe we should define "loud" and how big of an area your trying to fill with sound,on average.
    EndersShadow Posts: 17,687
    edited July 2011
    bfor916 wrote: »
    1. Monitor 70s $380
    2. Tsi400 $380
    Given the power of your 371, personally I would go with Monitor 60's.....
    But all the choices you listed are good ones and I doubt you would be second guessing yourself.
  • bfor916
    bfor916 Posts: 2
    edited July 2011
    would it be better to put money into an upgraded receiver and instead save money on the speakers by getting the monitor 60s?
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited July 2011
    That receiver is rated at 80w/ch in 2 ch mode. It will drive the m70's but I'm not sure how good they will sound... If you plan to blast it using that receiver, I defniitely advise against m70's, not even sure of m60s.
    But really, I would lean in the direction tonyb is stearing you. Polk speakers in general, are more focused around nice/clean/quality ht surround sound that are good at bringing out details in your sound source. With polk it's about finess, not volume and brute force of sound. You want something that bumps and is loud, you probably should consider a different brand. Cervin vega seems to be a popular college dorm workhorse. I'm sure there are others.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • Joe08867
    Joe08867 Posts: 3,919
    edited July 2011
    Cerwin Vega, BIC or PA speakers.
    If you really want to party down Polk's may not be what you want. They can do it but if you get to crazy they will let you know about it too.
  • Esreuter
    Esreuter Posts: 176
    edited July 2011
    To bfor916,
    I have to jump in with every one else here. get cerwin vegas, loud and tough.
    Being a college grad myself, i had built a loud system, involving the cerwin vega 12" towers, jbl center and rears. I drove it with a sony 1600es.
    The system was good for smaller parties, once the kegs got in full swing it was hard to over power the crowd.
    depending on your type of parties, if your going full kegger youll want a dj PA system.
    just some peeps and some brews, get a home system of the vegas and a avr.
    Being new to the forums and to polk myself, this line is geared toward the quality of sound over pure mass sound.
    hope this helps.
    Thank you for giving me my first opportunity to give some advice!
    ESR:biggrin::biggrin::biggrin:
    AVR: Sony 5600ES
    Center: CS2II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
    Front: Monitor 70 II (Clarity Caps PX, Perfect Lay coils, Mundorf resistors)
    Surrounds: Monitor 40 II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
    Rear Surrounds: Monitor 40 II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
    More to come :biggrin:
