Got my BJC Speaker wire
matchan
matchan Posts: 73
I ordered some 12 AWG Belden Speaker wire from Blue Jean Cable . Came via Fedex today. Neatly packed.
Currently running 12 AWG monoprice. Plan is to replace L-R-C with BJC wire/nakamachi plug...
Will post back my review
BTW, Dealing with BJC was a pleasure. Fast shipping, perfectly cut (exactly the length I ordered to the mm). Friendly emails
Post edited by matchan on
  • gdb
    gdb Posts: 6,012
    edited July 2011
    You should have had them terminated there, send them back to be "finished", and if the crap Nakafakies show up.....throw them in the bushes!:wink: you can thank F1 later.:biggrin:
  • fbm211
    fbm211 Posts: 1,488
    edited July 2011
    Yeah...Get yourself some GLS or Furez banana plugs.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • breal74
    breal74 Posts: 324
    edited July 2011
    Very happy with my GLS bananas that I put on some Canare 4s11!
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2011
    Matchan - Didn't you just say this recently? Good luck with the upgrade, it's not bad cable.
    "monoprice is unbeatable for the price. cant imagine any other wire being better than this one - atleast better percieved sound quality"
