LSIFX Speaker Stands
cembros
cembros Posts: 172
I'm moving into a new town home where I cannot effectively mount my surrounds on the wall. It looks like I will have to resort to speaker stands. Can anyone with such a setup share some pictures? Also, if anyone has any suggestions for stands I would appreciate it.
    F1nut Posts: 52,368
    edited July 2011
  • cembros
    cembros Posts: 172
    edited July 2011
    thank you for the suggestion but unfortunately the lsifx weigh 50lbs and these only suppost 25lbs. It's going to be tough to find something that meets my needs
  • dorokusai
    dorokusai Posts: 25,642
    edited July 2011
    I have a set of steel stands, spiked and shot loadable that I'd like to move down the road. They will handle the weight and size of the LSiFX with no problem. I'll price them very nicely.
    Send me a PM and let's exchange emails.
  • cembros
    cembros Posts: 172
    edited July 2011
    how tall are they? Unfortunately they look like they may be a little short my my application.
  • dorokusai
    edited July 2011
    Everything is above. I have a pair of speakers of the approximate height if you want a reference. I would watch the height as they will be very unstable the higher you go and that's a heavy loudspeaker.
    The height is fine as the surround will be dipole or bipole anyways, not directional like a traditional speaker. I don't believe it's an issue at all and I'm familiar with that entire line.
