amp hotter on one side
samnor
Hi, I have a parasound hca-1500 and it appears the left side of the amp gets hotter than the right... Is this due to a shift in the bias current and am I going to fry something if I keep it running like this.
Fronts: Wharfedale diamond 9.6
Sub: Wharfedale sw250
Rears: Wharfedale diamond 9.1
Center: Paradigm cc-350
Pre-amp: Oppo dv981hd
Amp for fronts: Parasound hca-1500a
Amp for rears: Adcom gfa-5400
Amp for center: Marantz MA500 monoblock
Polk multimedia speakers for PC setup
Post edited by samnor on
If the amp is laid out symmetrically, then the answer is yes and you should get it fixed.Political Correctness'.........defined
