amp hotter on one side
samnor
samnor Posts: 155
edited July 2011 in Electronics
Hi, I have a parasound hca-1500 and it appears the left side of the amp gets hotter than the right... Is this due to a shift in the bias current and am I going to fry something if I keep it running like this.
Fronts: Wharfedale diamond 9.6
Sub: Wharfedale sw250
Rears: Wharfedale diamond 9.1
Center: Paradigm cc-350
Pre-amp: Oppo dv981hd
Amp for fronts: Parasound hca-1500a
Amp for rears: Adcom gfa-5400
Amp for center: Marantz MA500 monoblock
Polk multimedia speakers for PC setup
Post edited by samnor on
    F1nut Posts: 51,786
    edited July 2011
    If the amp is laid out symmetrically, then the answer is yes and you should get it fixed.
