not clear on bi-amping
leftwinger57
Hello guys,Right now I own an Adcom gfa555 200wpc rack style amp and did notice a small toggle switch in the rear for brigding amps. If some one like me only has one set of speakers what does this do. Does putting amps in parraell increase quality or volume or maybe I'm just off on this theory.
I if one could afford such an amp would go for a Mac 2105 which is ss as is the Adcom so please inform me w/o reading an engineering book. Thanks....
Bridging and bi-amping are two different things, which are you asking about ?HT SYSTEM-
lsi 9's -
tonyb is correct, they are not the same at all and bi-amping has nothing to do with the toggle switch. If you are thinking about flipping the toggle switch, you would turn your 2-channel amp into a 1-channel amp. It doesn't directly have anything to do with quality or volume.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
Thanks alot , said switch will not be touched....2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
