rti6 "too big to use as rears?" maybe a dumb question
im assuming that sonically their is no such thing as "too big"
Am I wrong? and id rather have any of the rti or rtia fx speakers if anyone wants to trade :biggrin:
fyi
rti8 mains
csi3 center(getting 5 soon)
rti6 rears
fyi
rti8 mains
rti6 rears
Post edited by jojomgee on
They will work great as direct firing rear surrounds. I use the RTi4 in the rear, with FXi3s as my side surrounds. I would also suggest you opt for the CSi5 or CSiA6 instead of the one in your sig line.Shoot the jumper.....................BALLIN.............!!!!!
right now i cant go 7.1
id like to do 6.1
buy a 5 or a6 move the 3 to the back
and have f/x for rears
ill get it done -
fyi
rti8 mains
rti6 rears
naw better to big than to small , I heard of a system 15 years ago it used 5 klipsch heresys (1 center,2 mains, 2 surrounds) and a big sub , I heard it was very impressive . -
what amp?
I used to run RTi6's as surrounds with some RTi8's and a CSi5 up front. Made for an excellent HT setup. The RTi6's are rather largish, but if you have the space to accommodate them, there's no reason not to use them.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I loved using the rti6 for back duty and the bass is great
what amp?
I wish I knew , back then was before I started on ampquest , since than the best way to put it now is my ears grew up or I hear in colour .
