rti6 "too big to use as rears?" maybe a dumb question
jojomgee
jojomgee Posts: 198
edited July 2011 in Speakers
im assuming that sonically their is no such thing as "too big"
Am I wrong? and id rather have any of the rti or rtia fx speakers if anyone wants to trade :biggrin:
fyi
rti8 mains
csi3 center(getting 5 soon)
rti6 rears
Post edited by jojomgee on
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2011
    They will work great as direct firing rear surrounds. I use the RTi4 in the rear, with FXi3s as my side surrounds. I would also suggest you opt for the CSi5 or CSiA6 instead of the one in your sig line.
  • jojomgee
    jojomgee Posts: 198
    edited July 2011
    right now i cant go 7.1
    id like to do 6.1
    buy a 5 or a6 move the 3 to the back
    and have f/x for rears
    ill get it done
  • 20hz
    20hz Posts: 636
    edited July 2011
    jojomgee wrote: »
    fyi
    rti8 mains
    rti6 rears
    naw better to big than to small , I heard of a system 15 years ago it used 5 klipsch heresys (1 center,2 mains, 2 surrounds) and a big sub , I heard it was very impressive .
  • matchan
    matchan Posts: 73
    edited July 2011
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited July 2011
    I used to run RTi6's as surrounds with some RTi8's and a CSi5 up front. Made for an excellent HT setup. The RTi6's are rather largish, but if you have the space to accommodate them, there's no reason not to use them.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited July 2011
    I loved using the rti6 for back duty and the bass is great
  • 20hz
    20hz Posts: 636
    edited July 2011
    matchan wrote: »
    what amp?
    I wish I knew , back then was before I started on ampquest , since than the best way to put it now is my ears grew up or I hear in colour .
