just sold my rti12's getting lsi15 for ht and music
hello, i am going to get a set of lsi15 , can it handle 600watt carver pm 1.5 4ohm, i just got my carver pm 1.5 rebuilt(by CAR) with poly capacitors, back to factory specs, i currently have rti12's pm 1.5 450watts 8ohm rocks them. now i just sold my rti12 for lsi15 , was i right to get lsi15, this is for ht and music, my center is boston acoustics 325c,i had a lsic , did not think it did the jobs for vocal as the ba 325c does.i hear nothing good but the best of lsi15 . so it can handle that power , how much do you guys run. i want more clarity , the rti12's slap you , they sound great. i want more the ht and clearer sound in music.the carver rebuilt with poly sounds great,new quiet fan
receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
mains-lsi15 4ohm 250w modified&db840 nordost blueheaven spk/rca
center : snell xa1900 4ohm 250w,nordost flatline
subs-klipsch-ksw10/athena asp-4100
rear-OWM3 - 8ohm 100w
surrounds-klipsch rs-7 150w
amp-5ch.-aragon 3005 thx ultra 2 nordost blue heaven ls pc
power.c-bpt cpc/ps.soloist ci.
Post edited by deseroner on
Love my 15's being powered by a Carver tfm-55. I'm pretty sure they can handle whatever power you can throw at them.Things work out best for those who make the best of the way things work out.-John Wooden
^ thanks , well 600 wpc 4ohm.receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
power.c-bpt cpc/ps.soloist ci. -
with a more powerful amp as mine, will the subwoofer come alivereceiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
After fighting constantly trying to get my 25s dialed in, I wish I had started with the 15s...good luck with the systemLiving Room
Toshiba 55" 240HZ LCD
Onkyo TX-NR807
Emotiva XPA-5
HTPC
Polk Audio LSi 25 - Mains
Polk Audio LSiC - Center
Polk Audio LSi 9 - Surrounds
DSW microPRO 4000 x2 - Subs
Media Room
Mitsubishi 73" DLP
Onkyo TX-SR875
HTPC
2 x JBL Urei S300 Amplifiers
2 x JBL Urei S150 Amplifiers
JBL Synthesis Three S3M - Mains
JBL Synthesis Three S3HC - Center
JBL Synthesis Three S3S - Subs
JBL Synthesis Two S2A - Surrounds -
I am just curious here, why did you sell the rti12s? Just wanted to try something different or did they lack something?Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3 -
no they sound great with my rebuilt amp . just want to try something different.i had a lsic , the tweeter was great.Lietuvis91 wrote: »I am just curious here, why did you sell the rti12s? Just wanted to try something different or did they lack something?receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
Yes, but not to the point of "thumping." Even with the db driver upgrade and XO mod, the 15's are not a slammin speaker.Things work out best for those who make the best of the way things work out.-John Wooden -
but they will sound clear and crisp, the amp i have is damn clear, with polypropylene capacitors and all new internals it should rock the lsi15's , hopefully they sound good for home theaterreceiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
Yes, they will sound clear and crisp.
Yes, they will sound good for HT (actually they'll be great
Enjoy!Things work out best for those who make the best of the way things work out.-John Wooden
