Sda crs crossover
Master1000
First thanks for any help. Cant find any information(Model #) on the SDA CRS bookshelf speakers crossover. It has 2 woofers and 2 tweeters. Seems to have 2 crossvers. Does anyone have this crossover for sale
Post edited by Master1000 on
They come up on eBay from time to time. What's wrong with yours?Political Correctness'.........defined
President of Club Polk -
Im not sure nothing looks burnt but it doesnt work doesnt have any fuses im at a lost
The schematic for your speakers is listed in a sticky at the top of this section. You will note that both boards have a poly switch (type of fuse) to protect the tweeters. If they have permanently tripped, you won't have much sound from the speakers. You can replace them or remove them and replace with a jumper.Political Correctness'.........defined
post some pic's and maybe we can helpJC approves....he told me so. (F-1 nut)
The polyswitch is the "blue" disc thingy next to the yellow cap--think of it as a tweeter fuse.They usually reset unles they are tripped out.You are using the interconnect cable between the two speakers,,right?JC approves....he told me so. (F-1 nut)
cant find cable saw a post about making a new cable using wire to wire blade connectors. crossover doesnt work only using 1 speaker
I bet your problem is the polyswitch, also call Polk Customer Service they can get you a Blade/Blade cable if you don't want to make one, if I recall they are about $30.
Good Luck!!! -
