flat sub cable
rooftop59
rooftop59 Posts: 8,120
Hey all,
I just purchased a sub that I want to set up as an end table. Can't run the wire on the ground or in wall and would prefer not to buy a wireless kit. So is there a such a thing as flat speaker cable that sounds decent and won't cost as much as the sub? Could i build one?
Thanks in advance!
Game Room 5.1.4:
Bedroom 2.1
Post edited by rooftop59 on
  • John K.
    John K. Posts: 822
    edited June 2011
    R59, you've left out most of the relevant details. You don't describe the sub, but assuming that it has an internal amplifier, you aren't going to be sending actual power to it, just audio signals, so you don't need a thick electrical wire to carry possibly more than 100 watts.
    You also don't indicate where this cable would be run(under a carpet, etc.?). There are mini-coaxial cables available and very thin electrical wire could be used for speaker level inputs on the sub, if that's what you have in mind, since essentially zero power is carried. So, more details would be helpful.
  • rooftop59
    edited June 2011
    Sorry. It has an internal amp and an outlet very close by. So basically I need an RCA cable to run from the avr to the sub. There is no carpet, it would be running along the baseboard of an exterior wall (so running through the wall is not an option). I am hoping some basically flat cable could run along the baseboards and be painted white. Is this possible?
    Game Room 5.1.4:
    Bedroom 2.1
  • John K.
    John K. Posts: 822
    edited June 2011
    Okay, so you're going to use the line level connection with coaxial cable. Coax is inherently round rather than flat, but it comes in various thicknesses and colors. Depending on how low a level of visibility would suit you, getting the Belden 1505F in white from Blue Jeans Cable here is a good option.
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2011
    Audiovox Acoustic Research makes a flat series of RCA cables, the FS series. Do a search. It's also priced well enough for John to like it.
  • rooftop59
    edited July 2011
    Thanks Mark that does look like the best option for my situation and budget. Would a basic stereo rca cable work? I know that a better cable would provide better results, but I'm kind of in a pinch here...
    Game Room 5.1.4:
    Bedroom 2.1
  • dorokusai
    edited July 2011
    That would work fine.
    edited July 2011
    I think Mapleshade too has flat ribbon cables, not cheap though.
    I like my cables like my women, full figured with rounded edges.
  • rooftop59
    edited July 2011
    Yea, I think that my best solution might be to just run a regular "full-figured" cable right along the baseboard just above the crown molding and then paint it the same color. Wouldn't be much different than the flat cable, and much cheaper since I already have several options to choose from.
    This is of course all dependent on whether or not I can convince my wife to let me keep this humongous sub :frown:
    Game Room 5.1.4:
    Bedroom 2.1
  • shawn474
    shawn474 Posts: 3,052
    edited July 2011
    rooftop59 wrote: »
    rooftop,
    Sounds like you are in the same situation I was in with my original room configuration. I ended up buying a 35 foot RCA from monoprice with a y splitter. I ended up taking off the baseboards and running the cable behind the baseboards and drilling a hole through the baseboard to feed the cable through behind the sub. It worked great and nobody saw the cables. It was a very clean look.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
    edited July 2011
    shawn474 wrote: »
    rooftop,
    If useing a regular cable, this approach works well. Consider that when you remove the baseboard, there's usually a space between the drywall and the floor big enough to shove that full figured cable into.
  • drummer86
    drummer86 Posts: 441
    edited July 2011
    Ditto on the running it behind the baseboard. It's easier than you'd think. If you really wanted a clean look you can even put an RCA plate on the wall next to the sub.
    Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
    Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
    HK AVR635 | Polk R30 | Sony DVD/SACD Player
