My DIY Sonosub is DONE!
tryrrthg
I finally finished my DIY sub. I bought the driver back in November and never had any extra cash or time to do anything with it until recently.
The sub sounds pretty good. I haven't had much time with her, but she is a step up from the predecessor (Polk PSW450).
The two problems I am having is that it doesn't seem to be playing as low as it should. Or maybe I just can't hear past 25hz, but it seems to be hitting brick wall after that, although I haven't really tested it fully to see, this was just from a few quick test tones. My design was supposed to be -3 dB's around 20 hz or so... Oh well, it still sounds pretty good.
The second "problem" is that I can localize the bass. Think it's mainly due to the pressure wave that it's creating in my little apartment. I can "sense" where the wave is coming from so that is kind of distracting. One things for sure, I'm definitely pissing off the neighbors!
A picture, you can see the "mini" PSW450 sitting next to the sonosub:
More construction and Misc. pictures.
Post edited by tryrrthg on
Looking good, looking good!
How are the endcaps coupled to the tube? Other than the threaded rods, that is.
Cheers,
Thanks Russ!Originally posted by RuSsMaN
Cheers,
Russ
Each 3/4" end cap has an MDF "plug" glued to it (the plug is the same inside diameter as the sonotube). The bottom plug is 1.5" and the top plug is 3/4". After plugging the tube with them I just caulked the seems to make sure no air leaks out.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Nice job Tryrrthg,
How are you going to cover it? What driver did you use? What are you using to power it? Volume, port length, etc, I want details and more pics!
I have found that if the sub is too close to the wall, the drywall will shake and you will be able to pinpoint the sub. Also make sure there are no air leaks around the driver, port etc. That could pe part of the output problem as well. I had a low (below 25 Hz) output and it turned out that the port volume was too large compared to the Vb. If you make a frequency response graph Doc can help you with the output problem.Graham -
Thanks!Originally posted by gatemplin
Nice job Tryrrthg,
There is a link in my original post to more pictures. but here it is again
I plan to have my wife make a fabric "sock" to slide over it and cover the sonotube. I'll try to check out some of the things you suggested but being in an apartment I can't drive this thing to it's potential. My wife and I are in the middle of buying our first house so in a few months I'll be able to let her loose!
The only other thing that I thought might be causing the localization is the sonotube vibrating...
The driver is an old SVS driver. It was their original driver before the ISD. It models VERY close to the Adire Shiva driver.
The sub is 114 liters tuned to around 20hz. 4" flared port 18" long. Using a 250 watt Parts Express sub amp that I got from scratch and dent for $90. It looks brand new to me!Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Thanks for the details, I missed the link. That is a quality job. I threw the numbers into LSPcad (shiva specs) and everthing seems good. It is flat until the mid twenties and then gradually rolls off. F10 is in the mid-teens. You should be feeling the low bass but I guess you wont know until you do a frequency response graph. I think I will try and take some pics of my finished sub and frequency response also.Graham
I had a feeling I should be getting more output but I was only doing some quick test tones at pretty low volumes (60 dB's or lower) so the output probably was too low to even hear. I like it a lot reguardless. One day I'd like to put it in a box to see if the vibrating sonotube is causing the localization.
Thanks again for the compliments!Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Very cool...
I don't know if I'm missing something here, but I've always been told if you can localize the sub, the crossover setting is too high. Where is your crossover set? Did you try to lower it?
Also, where did you get that round tube? What is it exactly? What is it made of? It looks like cardboard.Bob Mayo, on the keyboards. Bob Mayo. -
Of course you can tell where it's coming from, even though low bass in non-directional, it still radiates from a single location (many people overlook this when the argue about whether bass is non-directional or not).
Sure, if you can get far enough away from your sub, you may not be able to tell exactly where its at, which is what people try to achieve, but I'm guessing your about 12 feet from it or less.
Basically, don't sweat it! You'll get used to it, and it will eventually stop bothering you.
Regards,
PolkThug -
Thanks!Originally posted by gmorris
Very cool...
I've got my crossover set at 40hz (12 dB's per octave). so it's pretty low. I can't go any lower.
The round tube is sonotube. It's used for pouring concrete. It is cardboard but very rigid. A lot of people in the DIY sub community use it. Check this outSony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
I'm probably only about 8 feet from the sub. our apartment is SMALL!Originally posted by PolkThug
Regards,
PolkThugSony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
What program did you use, if any, for the design??
one criticism,
the sonotube is upside down.... it would have been easier to read the writing if you had flipped it right side up....
anyway, when do you want to make that trip over to Progressive Audio?Bob Mayo, on the keyboards. Bob Mayo. -
ha ha! yeah the tube is upside down but the bottom was a tighter fit for the plug with the driver. That's all getting covered up some day
Oh crap! I forgot all about that. We've been so busy trying to get a house bought. We just went into contract for a house just a couple miles down the street from Progressive. I'll see what I can do, but it's a crazy time right now.anyway, when do you want to make that trip over to Progressive Audio?
My wife does work on saturday, maybe we can do it then. we'll see...Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
That looks great, hope your tuning gets squared away, and you start breaking things.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
one criticism,
I just turned my monitor upside down and I could read it just fine
Looks great and sounds like a fun project -
Thanks! I'll probably just start cramming some poly-fil in there if I'm not getting the extension I want.Originally posted by dorokusai
My wife's exact words after my first demo "You better not break anything or I'll be really mad" mission accomplished
Nice work! DIY cylinder subs are cool.
Make sure the PE amp you bought doesn't have a built-in high pass filter at 25 or 20 Hz. Most of the PE's use an 18 Hz high pass IIRC, but maybe something is different with yours.
Easy way to tell is measure the amp output into a dummy load and drop the frequency; if the amp output starts to drop off quickly below a certain frequency, that's where your high pass is kicking in.
Consult with HBomb on this; he did the same thing to verify the high pass points on his SVS-01 Bass Box by Marchand Electronics. The filter points and the associated slopes were right on the bean.
Can't hurt to rule it out before you start blaming the sub or the design.
Doc"What we do in life echoes in eternity"
SVS -
Not to derail, but Spec....... Did ya get that pb2 ultra yet???
Ok back on trackMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
welcome to the wonderfull world of diy. and great looking sub. i bet you will want another soon to match matching subs is a must for the waf lol
Thanks Doc!Originally posted by Dr. Spec
Doc
I was told over at HTF DIY section that the rumble filter is around 19hz on the model that I have. I'll have to run some frequency sweeps sometime this weekend, if I can do it without pissing of the neighbors too much.
Someone over at HTF also mentioned that the slope on the crossover is only 12 dB's/octave so I'm still getting pretty decent output at 80hz and above (my crossover was at 40hz). So that could be the culprit also...
I did some listening with the new toy last night and was hearing some bass detail I'd never heard before. It was kind of spooky on some of the tracks.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Thanks! I think this is probably it for me for a while. Until I can convince the wife to let me go infinite baffle that is!Originally posted by goingganzo
Great stuff. I just wanted to say congratulations and job well done before I had to actually read this thread and ask all the questions I need to.Make it Funky!
Good to know the high pass is set to 19 Hz (I'd still verify that, though).
If you run a sweep, do it "near-field" at 1 meter, and split the distance between the woofer and the port with the mic.
Near-field will really help minimize the affect of room acoustics and much more accurately reflect the true FR of the sub.
If you really want to get crazy, do it outside, away from any borders/walls. But near-field is usually good enough."What we do in life echoes in eternity"
SVS -
Very impressive tryrrthg.
I am dying to build another, but would have no where to really put it in the current HT room. Such a fun and enjoyable project, they are.
I'm starting to piece together a small HT set-up in the living room and will most likely build a 12" sonsub for that rig.
Peace Out~:DIf...
Ron loves a film = don't even rent. -
Thanks! appreciate the comments!Originally posted by gidrah
I'll try to do some near field and listening position sweeps this weekend.Originally posted by Dr. Spec
can your RTA software be used with just a radio shack SPL meter or would I have to buy something special? Is there any RTA software that can just be used with the rat shack meter?
Thanks Ron! It really was a fun project. Although with all the circle's I cut I probably would try a box next time, would probably have cost me even less since the sonotube by the foot wasn't cheap...Originally posted by Ron-P
With your garage set up you should consider going infinite baffle. Buy another tempest and you'd have more than enough output for your room.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Yes, TrueRTA can be used with the RS meter. But you would need to still get the meter calibrated for correction factors. And the output from the meter tends to be high and also pretty distorted. People have tried the RS meter as a mic without much success.
The Behringer ECM8000 is a great measurement mic for the $$. Even out of the box, it's really flat. After professional calibration of the mic and preamp, and after automatic correction of the FR for the PC soundcard, the FR of my test rig is 10-25,000 Hz, +/- 1 dB or better.
The important thing to understand when using an amateur test rig like mine is that it has "clean limits" for the gain stages and for total sound pressure.
If I push a particular gain stage too far or overload the entire rig with too much sound pressure, it will start to introduce its own harmonic distortion.
It took me many hours of looping the entire rig (both with and without the mic) to determine the optimum settings for all the gain stages and find the overall pressure limits.
The pro-grade rigs and and high SPL mics (try $5,000 for starters) are certified "clean" up to around 160 dB, with extremely low noise floors too."What we do in life echoes in eternity"
SVS -
Thanks for the info Doc. I'll have to look into that stuff in the future.Originally posted by Dr. Spec
Thanks! The sub blends in pretty well considering the lack of crossover slopes. I've got the x-over as low as it will go (40hz) and I'm running my Dyn's full range (they'll hit low 40's on their own). The slope on the sub amp is a little shallow so I'm still getting a little too much output above 40hz. I'd like it to slope off a bit quicker. Hopefully I'll be able to purchase a Paradigm X-30 crossover in the near future to give me more connection options and help with blending the sub a bit better for 2-channel listening.Originally posted by ATCVenom
Awesome project! How well does this sub blend in with your Dyns? Looks like it was fun and rewarding in the end! Good on ya.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Good job! It's a very intimidating beast. BTW I've been to progressive audio. Pretty awesome place. Maybe the Wilson Grand Slamms are still for sale. Only $45,000 give or take. hehehe. Love the B&W room.
Thanks!Originally posted by del44
Last I was at Progressive they didn't even have the Grand Slamms hooked up. They were just sitting there doing nothing. They had the Wilson Watt Puppies running in their best room. Come to think of it the Grand Slamms have been sitting in the same spot for over a year and a half. They had some Avalon's running before the Watt Puppies. Loved those Avalons!Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
