12v trigger help
Tmyckow
I recently purchase a parasound 2205a amp which has a 12v trigger as does my AVR. However the AVR as a 1/8mm plug but the amp doesn't. It seem to have something that close resembles speaker input. From what I can tell it looks like it had a place for 12v and ground. How can I connect the two. I have a spare 1/8mm to 1/8mm (both male) cable. Can I cut this open and disconnect the appropriate wires or is there a better way?
Post edited by Tmyckow on
What the trigger looks like. -
If you got a 1/8" plug you could strip it and install it on the amp screws.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I also have a 2205a and as disneyjoe just said cut off the connector from the cable and strip it back for connection. I would recommend using crimp-on fork or ring terminals at the end to contain the stranded wire and provide a good connection.
BTW....very nice amp.Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU. -
So... I did just that and found 3 individual cables inside. Red, white and yellow. Been trying a few combinations but nothing has worked yet. Any idea which color is what?
Or do I need to use a 1/8" momo for this to work. -
1/8" mono should work - I think the inner wire is the signal wire and outer wire is ground. (or the other way around). Should work w/ a stereo cable as well - I remember finding the diagram via google and also doing a little trial and error.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
I'm thinking off the top of my head, Yellow is ground the Red or and White should be +.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Call Tony at Parasound and he will mail you a correct 12v plug. He did for me at least and I would assume he would do the same for you.Living Room
LSi 15
LSi7
LSiC
LSiFX
2 EPIK Empire
2 W4S Sx-1000
Monster HTPS 7000 MKII
Parasound 5250
Onkyo PR-SC5508
Oppo BDP-95
Pro-Ject RM 1.3
LG 55 LED
Bedroom
RTi A7
CSi A6
FXi A6
2 PSW 125
Onkyo TX-NR1008
Panasonic 60 Plasma -
Although I have 1/8" plugs on both components I have to use a mono cable for mine to work.AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
The plug you are trying to use is a stereo plug, you will need a mono plug.
Simply pick up a mono cable from the shack, cut one end off, leaving the male plug on the wire, strip the ends, take an ohm meter & detirmine which wire goes to which part of the plug. the end of the plug will be your + and the next ring down is -. Connect to the appropriate terminals & you're done.
