12v trigger help
Tmyckow
Tmyckow Posts: 13
edited July 2011 in Electronics
I recently purchase a parasound 2205a amp which has a 12v trigger as does my AVR. However the AVR as a 1/8mm plug but the amp doesn't. It seem to have something that close resembles speaker input. From what I can tell it looks like it had a place for 12v and ground. How can I connect the two. I have a spare 1/8mm to 1/8mm (both male) cable. Can I cut this open and disconnect the appropriate wires or is there a better way?
Post edited by Tmyckow on
  • Tmyckow
    Tmyckow Posts: 13
    edited July 2011
    What the trigger looks like.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2011
    If you got a 1/8" plug you could strip it and install it on the amp screws.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Amherst
    Amherst Posts: 695
    edited July 2011
    I also have a 2205a and as disneyjoe just said cut off the connector from the cable and strip it back for connection. I would recommend using crimp-on fork or ring terminals at the end to contain the stranded wire and provide a good connection.
    BTW....very nice amp.
    Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
    Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
    Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU.
  • Tmyckow
    Tmyckow Posts: 13
    edited July 2011
    So... I did just that and found 3 individual cables inside. Red, white and yellow. Been trying a few combinations but nothing has worked yet. Any idea which color is what?
    Or do I need to use a 1/8" momo for this to work.
  • PrazVT
    PrazVT Posts: 1,607
    edited July 2011
    1/8" mono should work - I think the inner wire is the signal wire and outer wire is ground. (or the other way around). Should work w/ a stereo cable as well - I remember finding the diagram via google and also doing a little trial and error.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • disneyjoe7
    edited July 2011
    I'm thinking off the top of my head, Yellow is ground the Red or and White should be +.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • carwashguy
    carwashguy Posts: 131
    edited July 2011
    Call Tony at Parasound and he will mail you a correct 12v plug. He did for me at least and I would assume he would do the same for you.
    Living Room
    LSi 15
    LSi7
    LSiC
    LSiFX
    2 EPIK Empire
    2 W4S Sx-1000
    Monster HTPS 7000 MKII
    Parasound 5250
    Onkyo PR-SC5508
    Oppo BDP-95
    Pro-Ject RM 1.3
    LG 55 LED
    Bedroom
    RTi A7
    CSi A6
    FXi A6
    2 PSW 125
    Onkyo TX-NR1008
    Panasonic 60 Plasma
  • MADGSF
    MADGSF Posts: 603
    edited July 2011
    Although I have 1/8" plugs on both components I have to use a mono cable for mine to work.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • carvcom
    carvcom Posts: 240
    edited July 2011
    The plug you are trying to use is a stereo plug, you will need a mono plug.
    Simply pick up a mono cable from the shack, cut one end off, leaving the male plug on the wire, strip the ends, take an ohm meter & detirmine which wire goes to which part of the plug. the end of the plug will be your + and the next ring down is -. Connect to the appropriate terminals & you're done.
