What would you do?
I did not know if this should be in the sub or electronics thread, so…
What upgrade should I do next? A SVS PB2 Plus sub (Eric at SAS said this is the one I want), or a Sunfire Cinema 7 Signature 400x7 amp and use my h/k as a pre/pro for now. I know the 55x5 from the receiver just does not do my RTi150s justice, however my sub can’t seam to cut the mustard either. These will be part of my under construction 16 x 24 HT. Eventually (tax return $) I will get both, just curious what some of you would do first.
Current setup-
Receiver, h/k AVR 320
Front Mains, Polk RTi150
Center, Polk CSi40
Side Surrounds, Polk FXi50
Rear Surrounds, Polk RTi38 (new in box for future 7.1)
Sub, Polk PSW350
Post edited by mangata572 on
