Pin to pin for SDA.........
Unknown
edited July 2011 in DIY, Mods & Tweaks
I have a real jerkoff on this forum wanting me to make him a pin to pin SDA umbilical cable for his SDA's.
I will not mention any names.:biggrin:
Wondering if someone knows where to order that particular pin for this project.
It will be a stock input, I just need the pin.
Will a Nordost type/style banana work?
Smaller, bigger?
I have no idea at this point.
I know nothing about this cable never having any experience with SDA's so any help would be greatly appreciated.
Looking for some opinions here.
Many thanks in advance.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2011
    Ben would know as he has made quite a few of those cables.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
    Tony M Posts: 11,673
    edited July 2011
    I doubt he's a ****..
    If you a quality cable, get Bens advice.:wink:
    The cable can be made from almost ANY rca plug end. Just snap the outer ring off or with higher end ENDS, you might have to saw that outer part off.
    I made one for myself per this forums advice and it works great.I took a interconnect cable of good quality and snaped those four pressure plates off. that alows the pin to be inserted the whole legnth of the pin. It stays snug also. If it's loose , try to carefully spread that pin apart a little bit.
    This cheap version of this cable is so easy to make, even a caveman can do it..:biggrin:
  • Systems
    Systems Posts: 14,872
    edited July 2011
    What are you trying to say Tony?:biggrin:
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    edited July 2011
    Have never made an improved SDA I/C cable, but have replaced the PB connection with another pair of binding posts. :wink:
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2011
    I'd suggest the upgrade of the PB connection, on the binding post plate, to something more industry standard, then your options are endless.
  • Systems
    edited July 2011
    dorokusai wrote: »
    So there is only a single input right?
    So a single 5 way binding post so you could use banana plug/spade?
    Not sure what that means.
    You know this "jerk off" Mike!:biggrin:
    Testing
    Testing
    Testing
  • brgman
    brgman Posts: 2,859
    edited July 2011
    HEY! I resemble that remark!
    I’M OFFENDED!!!!
  • Systems
    edited July 2011
    brgman wrote: »
    Oooops.
    Thought he was asleep!:eek:
    Testing
    Testing
    Testing
  • Systems
    edited July 2011
    I think I will pass on that idea!:wink:
    Testing
    Testing
    Testing
  • dorokusai
    edited July 2011
    pepster wrote: »
    Yes, and a Banana termination will obviously work. I've made about a dozen over the years in all kinds of configurations.
  • Systems
    edited July 2011
    dorokusai wrote: »
    Athanku sir, the info is much apreciated!:wink:
    Testing
    Testing
    Testing
  • Systems
    edited July 2011
    Thanks all of you for the info, I truely appreciate it!
    Testing
    Testing
    Testing
  • Systems
    edited July 2011
    Overkill?
    XLO 4 conductor IC cable with GLS (split pin) rca plug (Cardas Quad solder).
    Testing
    Testing
    Testing
  • gdb
    gdb Posts: 6,012
    edited July 2011
    Nah, overkill would be a welding lead and a welding lead terminal plug/socket.:biggrin:
  • Systems
    edited July 2011
    It came out to about 16 ga. when all were twisted together, so should be larger than stock anyway (18 ga.).
    Now to do a 12 ga!:wink:
    Testing
    Testing
    Testing
    Toolfan66 Posts: 18,126
    edited July 2011
  • Systems
    edited July 2011
    Thanks Tool, its my "virgin" SDA cable!:tongue:
    Testing
    Testing
    Testing
    edited July 2011
    Nice work on that cable.:wink:
  • Systems
    edited July 2011
    Thanks Tony.
    Naturally I see a couple of flaws, but promise the next one will be perfect!:wink:
    Testing
    Testing
    Testing
