The Adcom GDA 600 modification thread
Trying to remedy "digititus" on violins and aggressive edge on combined female vocalists. The Genki analog out reduces this compared to the Adcom mod output but loses high frequency sheen/air. Toying with buying a Dlink III since it has an upgrade path with Cullen and touts its design as addressing this issue.
Well I suspect it's a system synergy thing or you might have some high frequency oscillation's.Though this is unlikely if you have the opamps bypassed properly.You might try rolling some different opamps in there and see if you can find one with a softer presention in the treble that would be more to your liking.
actually I've done the full upgrade in this thread, and have enjoyed since about May last year. But with my speaker upgrade to MG1.7's there is no mercy shown to bad inputs. While experimenting with the Music Streamer II I did get some relief by upsampling to 96khz and as bit depth improved the problem disappeared ( as did imaging). So I'm not entirely certain that the problem is equipment so much as 44.1khz recording limits. Examples of recordings that exhibit this
Norah Jones - Come Away With Me
Dixie Chicks - Taking the Long Way
KT Tunstall - Eye to the Telescope
Michael Jackson - Thriller -
BTB i did buy a PS Audio Jewel power cable and use with the Adcom, definite improvement in base and percussive transients. So will be buying a few more and adding IEC connectors to my CJ-PV10A, and MC modded Hafler.
decided based on echidnas comments to buy some better cables... always been a skeptic when it comes to digital cables. Bought some Monster cable M850 digital cables (both RCA and toslink). The toslink was an immediate improvement over the cheaper THX toslink cable I was using into an Oppo DV970, reducing or eliminating sizzle and clarifying snare drum whacks. Comparing the RCA out of the Oppo, it didn't eliminate sizzle as well but power design could easily account for difference.
As to remaining edge on vocalists, will see what happens later this week as I alter pre and amp to IEC connectors and upgraded power cables all around, including transports. -
echidna, 100uf is a pretty big value, are you sure you don't mean pf?
At this point I have completely replaced all my cables, using some Analysis Plus Oval One
and Audioquest Black Mamba II from Audio Advisor.... the old cables were 90% of the glare issue and what edge remains I'm fairly certain is the Hafler amp. What's really surprised me is that I now prefer the Linn Genki analog out to its digital output through the Adcom DAC. -
This was a fun mod,,mine is still working well.JC approves....he told me so. (F-1 nut)
Mine sounds incredible. Thanks again to you and Fred. Still have to install the Burson rectifiers. Probably in the Fall/Winter when I actually have some time."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul!
Same, I havent installed the Bursons yet either. But the dac gets airtime everyday, really dig this little black box now. Think I may even try some Auricaps in it, really liked em in my old preamp.
Regardless if I find something I like better, Im thinking the Adcom will stay stay forever. Thanks again to Fred and George, I blame ya both.
DaveOnce again we meet at last. -
Just be aware the Auricap leads won't fit in the pcb and IIRC, they don't have values available. The REL Multicaps were the only one's I felt comfortable the leads would fit and they were snug.
Of course you can probably "rig" something up, but to the best of my knowledge only the small Sonicaps or REL would fit as stock as well as having the proper values. If I could have done Auricaps, I would have............best budget coupling cap going, IMO.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
+1 on the caps,,the Burson's were not too bad,,and yes-- a huge thanks to Fred,for without his guidence/support I would have never been able to finish this project.JC approves....he told me so. (F-1 nut)
Getting the value's right may be a pita. But luckily I thought ahead (for once) when doing this initially and saved all of the clipped leads from the Sonicaps because of the pcb opening size. Not a perfect fix, but could always just go from pcb to lead, then lead to new cap lead, if ya get my drift hah. Had to do this with my Acoustats, try to fit the lead off of a 100uf poly into a pcb hole made for a 100uf electrolytic, not happening.
I agree with you about the Auricaps, there is just something special that they do, they sound much more natural than others if you would. And the decay... it really is scary good. Notes hang and disappear perfectly, almost too perfect perhaps. But yeah I really dug em in my old custom pre, the Auricaps realy made the difference for me.
I have Auricaps stock in a couple of my tube pieces and really like them. I actually stopped at Parts Express in Ohio on the way back from Ricardo's (we went to Polk Fest last year) and picked up some other Auricaps to install in another tube piece of gear, saved a little on shipping since it's not too far from Ricardo's house.
Good idea on saving the leads.............now good luck finding the values.
Seems you are right. Those value's are unobtainium.
Looks like it may be time to try something new, if I can find the right size's.
Good to see you gents still enjoy the fruits of your labours.
Regardless if I find something I like better, Im thinking the Adcom will stay stay forever. -
Dave
Sonicap has a sale going--thats where I got mine from(Sonicaps fit just fine)JC approves....he told me so. (F-1 nut) -
Fred no question about it, its staying. Actually planning a move to Australia next year, my wife asked about which electronics Im going to take/ship there, I told her the little black box with the red light on it, aka the Adcom. May ship speaker's also (LSi9's), but looks like electronics arent to hard to come by.
George I have the Sonicaps in it now, just really dig Auricaps in other components, so thought I would givem a try. Doesnt look like that'll happen though.
Yes their voltage is 240. Im glad you brought it up, was going to ask in a pm at some point haha. Thanks
Your welcome,if you take a look at the pic's of the power supply Brock posted in post #74 on page 3 you'll see two brown jumpers in the R100 and R102 positions.By removing both of these then adding one to the R101 spot will make it 230/240 ready.You might also want to reduce the fuse amperage to roughly half the value.
FTGV and Poee7R I imported my dac from the US last year and converted it to 240v as described....Other things to note are normal beer (super) is 5% alcohol,
most important we drive on the other side of the road.
Add to that most important list is how you folks greet "Good-die Mite" as in "Gooday Mate" to the tourists on the street. I almost punch the guy and broke his nose first time I was greeted. Joking of course :biggrin:Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Thanks echidna, Im trying to prepare for alot. My wife and I were in Brisbane (where she is from) for a month, beautiful place.
Gonna be a wild ride.
Did he have a really big knife and answer to the name Dundee? -
The guy looked like Chuck Norris. I almost think he is an Aussie version of Chuck.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Dave
Dave,
The land of Aussies is a very beautiful place with a very nice Sunset in the evening. Fish are aplenty and they makes excellent wine too. I can only envy you to be moving there. Is that a permanent move or a temp stay?
Good Luck!Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Haha Im not big on fish and I dont really drink, but my wife enjoys both. Its a permanent move, not sure if we'll live in Brisbane the entire time, as I would like to see alot of the country. May end up buying an RV or ute (truck) and camper or something of the sort, and take a long, long drive. My father-in-law did something similiar when he was younger, and the stories he has to tell are awesome. Would love to have the same sort of memories when the time comes to look back.
Kinda a big roll of the dice. But thats where the fun is, we dont have any kids and sold the business a while ago, gonna play it by ear and see what happens. Have long term goals of living in Europe also, so this is another step in that sense.
No place is safe.
Dave,
I don't know when you are moving (in a couple of months?) to the land down under but here is the video made for the land down under. Nice tunes to go with the funny video.
http://video.search.yahoo.com/search/video?p=men+at+work+down+under
JamesTrying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Hi guys, I just picked up one of these DACs today used for a couple bucks. This thread is one of the deciding factors to me dropping the cash for it.
Upon the first few listens, I do like the sound. I had two previous 'main' analog audio sources... A marantz cd5003 and an maudio audiophile192 pci card in a tiny passive computer case. I'm using the SPDIF output from the audiophile192 to run the DAC. (FLAC on a NAS + foobar2000 + ASIO plugin + maudio spdif out)
My initial impression is that I like the adcom better than the onboard AKM dac on the audiophile192, which I liked better than the Cirrus Logic set in the marantz.
But, I can tell that this is a little conjested (much like the sound blaster Xfi before opamp and power cap swaps)
I'm going to be picking up these BurrBrown ops and the caps. Gotta say that I'm excited to get working on it. -
annihilatorg wrote: »Hi guys, I just picked up one of these DACs today used for a couple bucks. This thread is one of the deciding factors to me dropping the cash for it.My initial impression is that I like the adcom better than the onboard AKM dac on the audiophile192, which I liked better than the Cirrus Logic set in the marantz.
I'm currently dabblingly with an AKM AK4396 based dac that sounds quite good mated to a hi perfomance Class A output buffer and reasonably clean power supply.It's not quite the equal of my Cirrus based unit but it has a superior power supply scheme and it better manages the incoming SPDIF data.
