Help!!!!!
edited June 2011 in Speakers
I was just inspecting my RT55's and I noticed one of the tweeters was looking funny
The sound is great so im not sure if this is really even an issue
i know this is probably the wrong place to post this thread but im panicking and need help ASAP
would this tweeter be considered bad? like i said sound is perfect :eek:
Post edited by jojomgee on
Welcome!
    edited June 2011
    It's ok, one of my Rt800's are like that, it still sounds fine.
    edited June 2011
    I am conemplating selling my whole rt setup I don't want anybody thinking I'm trying to pull a fast one if I sell with the dome like that.....any clue on how to get replacement casing & possible price
    edited June 2011
    Call Polk for replacement cost, and let them know you're a club Polk member for a discount.
    edited June 2011
    Looks like the cap is just pushed in. Try sucking it out with a vacuum cleaner,or put some tape on it and pull it out carefully. Or just leave it be, it won't affect the sound.
    edited June 2011
    i removed the surrounding so i could get to the dome...and even when i push it into place it goes right back?....
    still sounds great so im not worried
    thanx fellaz
    edited June 2011
    There was a thread for a repair with a hair dryer in the last week or so...someone post up guys
    Anyway if you decide to push it back out again maybe hold the hair dryer to it an it might hold shape
    edited June 2011
    I will give that a try....thx....hopefully it works
    edited June 2011
    Warm it up with a hair dryer and then spray it with one of those compressed air in a can like Wal Mart sells. You have to hold it upside down so it will freeze.
    That's what I found by searching around. I'd be sure sure to follow the OP's advice and know that you can get a replacement first before I try to shock that sucker back into submission. lol
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
Welcome!
Welcome!
