help from itunes guys or computer guys
EDUBAG
Hello guys,
this is very weird and i do not know what is going on so bear with me. i usually use itunes as my media player from my laptop. one day i installed mediamonkey since a lot of people here like it better, i was not one of them, so i unistalled mediamonkey and went back to itunes.
the problem is that for some reason itunes is not getting a los of volume out from the computer, i mean it seems that the itunes software and the soundcard or the volume control are enemies, you can barely hear any difference at any point using the volume control from itunes (you know the little bar). i thought it was the sound card, but opened windows media player and it provides proper volume control and output.
i reintalled itunes just in case it was an update problem or whatnot and did not make a difference.
could somebody please help me out since i like itunes and use it all over the house and cannot enjoy my music at low level volume.
thanks,
eduardo
thanks,
eduardo
HT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES
CSI3 CENTER
PSW 125 SUB
APPLE TV 160GB
2 CHANNEL:
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
Post edited by EDUBAG on
Never heard of that. You could try reinstalling the audio drivers maybe?If you will it, dude, it is no dream.
Silly question. Did you check your wav volume on the computer. It does use the computers volume controls.
Do you get the low volume under all conditions: playing through the internal speakers, using the output from your sound card (both analog and digital output), and streaming to your apple TV?
it is very very strange, hence the reason of my post, it only happens with itunes. right now i am using windows media player and it works like a charm but when i open itunes it sounds very very low.
HT:
CSI3 CENTER
PSW 125 SUB
APPLE TV 160GB
2 CHANNEL:
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
MIT EXP2 SPEAKER CABLES -
If you are using Windows, you may have a control panel called volume mixer (depends on version of Windows). Here you can set the volume for some programs independently. Try resetting the volume here for iTunes.
