Harman Kardon AVR 254
mdaudioguy
For sale is the current record holder for an AVR to remain in my system! It took me a full 15 months to get the itch again!
This unit has tremendous value! Don't let the watts per channel fool you. This 7.1 channel receiver will run a full complement of 8 ohm speakers nicely, but for future expansion and more potential, it has pre-out connections!
Includes remote, manual, and calibration microphone. Missing are the cheapo AM and FM antennas, but I think I could scrounge some up if you're really interested.
I take very good care of my gear. This AVR looks like new. I'm Polkie-pricing this to go at $200. If Paypal, then fees (if any) are your responsibility. You pay actual shipping/insurance costs from 21157. I prefer to ship Fedex, and I have the original packaging to ensure it arrives safely.
Btw, this is a great AVR to pair with RTi series Polks!
Thanks,
Ed
Thanks,
Ed
The Harman Kardon AVR 254 is the most affordable Harman Kardon receiver to feature both Dolby TrueHD and DTS-HD Master Audio/B] decoding on the audio side, and Faroudja DCDi Cinema video processing to 1080p on the video side. But there's plenty more to recommend the AVR 254, including three HDMI inputs, connections for external amplifiers [pre-outs], EzSet/EQ technology to fine-tune your system to the acoustics of your room, and an RS-232 port for future firmware upgrades. Perhaps the highest recommendation of all? As do all Harman Kardon A/V receivers, the AVR 254 features a high-current, ultrawide-bandwidth design for maximum fidelity. Bridge II is compatible with this model.
[Selected] SPECIFICATIONS
Audio
Stereo Mode
Continuous Average Power (FTC) per Channel: 65 Watts per channel, 20Hz - 20kHz, @ <0.07% THD, both channels driven into 8 ohms
Seven-Channel Surround Modes, Power per Individual Channel,
All Channels Operating at Full Power:
Front L & R Channels: 50 Watts per channel @ <0.07% THD, 20Hz - 20kHz into 8 ohms
Center Channel: 50 Watts @ <0.07% THD, 20Hz - 20kHz into 8 ohms
Surround Channels (L & R Side, L & R Back): 50 Watts per channel @ <0.07% THD, 20Hz - 20kHz into 8 ohms
Input Sensitivity/Impedance, Linear (High-Level): 200mV/47k ohms
Signal-to-Noise Ratio (IHF-A): 100dB
Surround System Adjacent Channel Separation:
Dolby Pro Logic I and II: 40dB
Dolby Digital: 55dB
DTS: 55dB
Frequency Response at 1W (+0dB, -3dB): 10Hz - 130kHz
High Instantaneous Current Capability (HCC): -35 Amps
Transient Intermodulation Distortion (TIM): Unmeasurable
Slew Rate: 40V/?sec
General
Power Requirement: AC 120V/60Hz
Power Consumption: 65W idle, 540W maximum (7 channels driven)
Unit Dimensions:
Width: 17-5/16" (440mm)
Height: 6-1/2" (165mm)
Depth: 15" (382mm)
Carton Dimensions (W x H x D): 21-7/8" x 10-1/2" x 18-5/16"
(555mm x 266mm x 465mm)
Unit Weight: 27.1 lb (12.3kg)
Shipping Weight (System, Accessories, Packing): 32.8 lb (14.9kg)
Post edited by mdaudioguy on
I have this same reciever and love it. Good luck with the saleFront - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
$200? Sheesh, steal of the day. It's feature packed and of all the little things I've liked about HK is that cool volume control. I've used a handful of HK AVR's for Surround Bar projects and installations and they're perfect. That's 65wpc of honest power, keep that in mind.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I have this receiver as well in the bedroom. Very good high current AVR.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Thanks guys! Just waiting for the right person to see this...
You have a pm
RodneyWoodford wrote: »You have a pm
PM replied. -
the hk's are tough, musical tanks....glwys
mike -
Mdaudioguy,
You have pm . Money sent -
Payment received - Thanks Rod! I'm going to pack it up now as securely as I can and I'll drop it off with the shipper tomorrow.
Ed -
Rod - Check your email for shipping info.
Mods - Please mark as SOLD.
Thanks!
Ed -
Ed, check you email again. and pm.
