Review: Advent Indoor/Outdoor speaker...
steveinaz
steveinaz Posts: 19,546
edited February 2009 in Speakers
Advent Calypso indoor/outdoor speaker
Price:
approx $59.00 pr (see Ebay, free shipping too!)
Description:
2-way ported indoor/outdoor speaker supplied with mount brackets and hardware. Wide in the front, then tapers into almost a triangular shape at the rear, making corner placement easier. Cabinet is ABS or some sort of durable plastic. 5-way gold plated single wire binding posts. 5" woofer, 1" tweeter.
Build:
Appear to be very well built, heavy for their size. The binding posts are very impressive on a speaker of this cost/type. Supplied brackets are also very well made and use a "ball/socket" arrangement--all hardware needed is included.
Listening:
Very impressive bass response from such a small speaker. Highs are smooth and have that classic "Advent" character. Smooth transistion from woofer to tweeter makes for nice mid-range as well; a very non-fatiguing sound, even when pushed hard. This is the best sounding indoor/outdoor I've auditioned--most are seriously lacking in bass (as to be expected) but the front firing ports on this model seem to help bass output and efficiency.
Comments:
If your looking for indoor/outdoor speaker, definitely give these a listen, I'm about to buy another set for the bedroom system--they sound that good.
Post edited by steveinaz on
  • steveinaz
    edited March 2004
    Pic:
  • amulford
    amulford Posts: 5,020
    edited March 2004
    What are they rated for? What are you driving them with?
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited March 2004
    I installed a pair of those on my sis-in-laws back deck. They are a GREAT speaker, especially at the current market rate.
    Cheers,
    Russ
  • amulford
    edited March 2004
    My curiosity is peaked...
    I wanna build a small 2 ch rig in my boathouse. The speakers need to be outdoor build.
  • steveinaz
    edited March 2004
    50 watts/rms. A Yamaha receiver, 75 watt/rms can't think of the model number, VRX...something? Hell, I dunno....its on the patio.
  • steveinaz
    edited March 2004
    Cheers,
    Russ
    They sound great huh? I'm really impressed. Best $59 bucks I've spent in awhile...
  • amulford
    edited March 2004
    Thanks Steve, I'm gonna check these out.
  • woodyjacobs
    woodyjacobs Posts: 706
    edited March 2004
    Agreed. I have two pair of the Marbl IIs (which preceeded this model...I think I pair about 40 a pair) and they are a great little speaker, particularly for that price. I am pretty sure they have the same drivers as the Calypso, just a bit different cosmetically.
    These were the reasons why I never hung my Atrium 45's outside and eventually sold them to Mark here on the forum...the Advents dig lower. And I'm all about some bass. I've had one pair outside now (they are under the roof overhang but still get some sun) for 2 1/2 years and they are still going strong. The black color is fading a bit, but they still sound great.
    I just don't see spening 200 bucks or more for speakers that are gonna fry in the sun and get frozen and rained on.
    system 1:
    Athena: AS-F1 mains, AS-C1 center, AS-B1 surrounds, AS-P400 sub, Yammie RXV-730, Rotel RB-976 driving front stage, Samsung BD3600 Blue Ray, Denon DVD2900 for sacd/cd , jbl n24awII on the deck, samsung 40" 1080p lcd
    system 2:
    XBox 360 Spherex 5.1 system, HK DVD38, Phillips CDC 926 CD changer, Phillips 32" LCD
    2 channel
    NAD 1600 pre, NAD 2400 THX amp, Phillips CDC 926, Linn extra speaks, crappy TT
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2004
    I am constantly amazed at how good a small speaker can sound...that is a real neat Advent.
  • steveinaz
    edited March 2004
    I was amazed with the quality of build. Very heavy, and very good quality binding post or such a cheap speaker.
  • woodyjacobs
    edited March 2004
    My old Advents Marbls do not have the binding post (just spring clips), but you are right about the build quality. When I was hanging my pair in the garage I knocked one off of a 6' stepladder onto the concrete floor. It didn't crack, the woofer magnet didn't detach...no problems. I was amazed.
    system 1:
    system 2:
    2 channel
  • Drumr
    Drumr Posts: 2
    I'm terribly sorry to bump such an ancient post and i know its against forum etiquette but I'm wondering if anyone knows how to remove the grills from the fronts of these speakers.
    Thanks in advance!
  • steveinaz
    I still have these, I attempted to remove the grills, no success--at least without damaging them. The Advents are going to do duty in my warehouse as soon as I fish the wires thru the walls.
  • Drumr
    Drumr Posts: 2
    thanks, i guess that's odd that they're not removable because they show the picture with them off and if they were removable you could get to the screws to service the insides.. but i guess at that price point they want you to buy new ones! ;)
