Ubuntu bridging ethernet ports
disneyjoe7
Any done this, and how... And yes Googled it and no they are over my head. :redface:
Feed in 192.168.0.X feed out need to feed a router / switch.
I need help in layman terms.
Thanks Steve
Thanks Steve
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
If this is too complex for you, you're going to have to get someone to do it for you.
https://help.ubuntu.com/community/NetworkConnectionBridgeTurntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Ok my problem is the command "brctl" isn't found... It comes back as "Command not found"
ip addr flush dev <interface 1>
ip addr flush dev <interface 2>
brctl addbr <bridge name>
brctl addif <bridge name> <interface 1> <interface 2>
ip link set dev <bridge name> up
I'm running Ubuntu 11.04
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
WMC Win7 32bit HD DVR -
did you install the bridge utils package, like one of the first steps tells you to?Turntable: Empire 208
Arm: Rega 300
Yes both of those steps worked fine.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
are you just running it, or are you doing "sudo brctl"?Turntable: Empire 208
Arm: Rega 300
make sure your environment path includes the directory where this command exists.
I would search for the command - to verify it is part of your OS build.
And if you search for it and find it - try 'cd'ing to the directory then execute the command to verify it works. Then verify the path is part of your environment.
I think I got things to work after I did these updates.. http://www.techdrivein.com/2011/04/12-things-i-did-after-installing-new.html
Then I redid the bridge updates and it understood the "brctl". Not sure everything is work ok if this computer is rebooted. I don't think its bridge then, do I need to do something for that?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Lost again.... What's wrong?
steve@steve-Deskpro:~$ sudo /etc/init.d/networking restart
[sudo] password for steve:
* Running /etc/init.d/networking restart is deprecated because it may not enable again some interfaces
* Reconfiguring network interfaces... Ignoring unknown interface eth0=eth0.
SIOCSIFADDR: No such device
br0: ERROR while getting interface flags: No such device
Failed to bring up br0.
[ OK ]
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Mind if I ask why you're doing that? Odds are what you're trying to do can be solved with less than about $30 of hardware.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
In short no, but if you or anyone got that response in an email keep it to yourself please.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Put this on your router (it's worth it, regardless):
http://www.dd-wrt.com/site/index
Then do this (there are many other solutions, google is your friend):
http://www.geeked.info/traffic-logging-with-wrtbwlog/
If your router doesn't support DD-WRT, well, it's about time for an upgrade, anyway.
You can lock out specific sites (for just her computer), only allow specific sites, only allow access at certain times of day, I think that there's time and MB metering, etc.
Probably a better solution than dealing with everything running through your computer and trying to watch it.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
I'm using dd-wrt with a WRT54G router, and this router is setup as wireless repeater and switch. Feeding a computer port, and a printer server.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Isn't this just what I'm trying to do?
"Probably a better solution than dealing with everything running through your computer and trying to watch it."
BTW I can do this under Windows with no problem. But like to do it in Ubuntu.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Oops. Just noticed your edit. Carry on, but I think you're going about this the hard way.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
