Standard Carver power cable to IEC?
brgman
brgman Posts: 2,859
edited June 2011 in Electronics
Has anyone done this? I s there a benefit to it? And cann anyone recommend someone who can do this in a quality manner if it is beneficial.
I’M OFFENDED!!!!
Post edited by brgman on
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2011
    I know I've seen at least two members with modified IEC to Carver units. I think it's a must do modification since it's not that hard and opens up a whole plethora of options after that.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited June 2011
    I can't speak specifically to Carver, but have had standard power cord connections replaced with quality IEC females on an NAD receiver, NAD amp, VTL amp, NAD preamp, Conrad Johnson preamp, Kenwood tuner, Fisher tuner and Conrad Johnson Sonographe CDP.
    I have about a dozen good to very good power cables I can roll and have experienced audible improvements on everything but the Fisher tuner.
    When I started the process I made the assumption that source components would be impacted the most, but have found the cords to amps also make a difference.
    Even after new dedicated circuits, quality PS Audio outlets and a power conditioner, the IEC cords make a difference. The most notable for me has always been a reduced noise floor. Other subtle changes in overall tone, improved bass, focus and soundstage can be noted with different cables.
    Overall, I favor my MIT IEC's over the rest.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • brgman
    brgman Posts: 2,859
    edited June 2011
    I would think it would be an upgrade.Hopefully someone who has done it speaks up.Thanks
    I’M OFFENDED!!!!
  • brgman
    brgman Posts: 2,859
    edited June 2011
    Looking for a reputable operation that cando this if anyone knows any.
    I’M OFFENDED!!!!
  • inspiredsports
    edited June 2011
    brgman wrote: »
    While they are not a Carver shop per se, Bill Thalmann here http://www.musictechnology.com has done a lot of work for me and they should be fairly close to you shipping-wise. The installation of an IEC is a pretty basic "Electronics 101" task.
    NAD SS rigs w/mods
    GIK panels
  • dorokusai
    edited June 2011
    Mike - Email me as there's someone near you in Baltimore that may do this if he's interested.
