Help mounting TL250
Hi
Can anybody help me how to mount my new TL250 on the wall???
Thanks,
Tony
Thanks,
Tony
Post edited by tony333 on
They just mount on the wall with screws. What seems to be the issue you are having?
Are you trying to mount them on some kind of wallmount?
Here is the manual
http://www.polkaudio.com/downloads/manuals/home/TL150_250_350_MN_2031C.pdf -
i just want to mount them on a regular wall. They have threaded keyhole on the back, Do i need some kind of special screws or brackets to make sure they fit well and not loose, as they are heavy too.
If you are mounting them on drywall and not on a stud I would purchase some drywall screws with matching anchors from the hardware store. If you feel that the end of the screw is not big enough to secure the speakers then one option is to add a small washer. I am sure that others will have ideas as well.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
ok thanks, i will see what i find at my nearest hardware store, its strange that there is nothing included inside box to mount these on a wall.
that's pretty typical actually, unless otherwise specified. Should be an easy job. good luck!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
