Help mounting TL250
tony333
tony333 Posts: 8
edited June 2011 in Speakers
Hi
Can anybody help me how to mount my new TL250 on the wall???
Thanks,
Tony
Post edited by tony333 on
  • Joe08867
    Joe08867 Posts: 3,919
    edited June 2011
    They just mount on the wall with screws. What seems to be the issue you are having?
    Are you trying to mount them on some kind of wallmount?
    Here is the manual
    http://www.polkaudio.com/downloads/manuals/home/TL150_250_350_MN_2031C.pdf
  • tony333
    tony333 Posts: 8
    edited June 2011
    i just want to mount them on a regular wall. They have threaded keyhole on the back, Do i need some kind of special screws or brackets to make sure they fit well and not loose, as they are heavy too.
  • rooftop59
    rooftop59 Posts: 8,121
    edited June 2011
    If you are mounting them on drywall and not on a stud I would purchase some drywall screws with matching anchors from the hardware store. If you feel that the end of the screw is not big enough to secure the speakers then one option is to add a small washer. I am sure that others will have ideas as well.
    Game Room 5.1.4:
    Bedroom 2.1
  • tony333
    tony333 Posts: 8
    edited June 2011
    ok thanks, i will see what i find at my nearest hardware store, its strange that there is nothing included inside box to mount these on a wall.
  • rooftop59
    edited June 2011
    that's pretty typical actually, unless otherwise specified. Should be an easy job. good luck!
    Game Room 5.1.4:
    Bedroom 2.1
