Powering RTi A7 & RTi A9
KYFHO
KYFHO Posts: 76
edited June 2011 in Speakers
I am about ready to purchase new fronts and have decided on either the RTi A7 or the RTi A9. I will be powering the speakers with a Denon AVR 4310CI. I am confident I can run the A7's with no problem but am unsure with the A9's. My point being if I were to go with the A9's would I need to power them with an additional amp to see their full potential?
Post edited by KYFHO on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited June 2011
    The more power the better, so yes an external amp is recommended but they'll sound good on your Denon. I ran mine on a Pioneer Elite avr without any problems. Definitely go with the A9's and later down the road when funds come available you can add an external amp. $400-$700 will get you a very nice used amp.
  • BtrSound
    BtrSound Posts: 123
    edited June 2011
    I have a 3311 and have both the rti a9s & a7s. Without an ampp they do sound good, but I found them to be a bt bright. I added an amp ant the mods and bass really came alive. It will sound good with just your receiver particularily if watching movies or two channel stereo, but I like to listen to music in multichannel where it sounds much better with an amp. With that said I would go with the rti a9's. They have a fuller sound. Hope this helps.
    Toolfan66 Posts: 17,992
    edited June 2011
    If you want the best out of them "GET AN AMP!!!!"
  • jbooker82
    jbooker82 Posts: 1,627
    edited June 2011
    I think getting an amp is true for about every speaker.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • SRTer
    SRTer Posts: 372
    edited June 2011
    KYFHO wrote: »
    I have both the RTi A9 and A7 towers running off a Pioneer Elite SC-35. I'm fully satisfied after I made adjustments to the automatically calibrated program the MCACC sets.
    You don't need a amp to get full clean powerful sound with this setup. However, an amp never hurts and could improve the sound just as any real upgrade to your system will.
    I would recommend the RTi A9 or A7. If you are not buying a amp, I think you would driver the RTi A7's better off the AVR you already own.
    If you have a really good sub, you could just go RTi A5's. If your are going to crossover the towers at 80Hz, RTi A5's is really all you need and a killer sub. They will play awesomely on a AVR with 100 watts.
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
    Receiver: Pioneer Elite SC-35 (140 watts x 7)
    Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
    Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
    TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
    Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks
  • Almadacr
    Almadacr Posts: 185
    edited June 2011
    leroyjr1 wrote: »
    + 1 This , you can get down the road the Emotiva XPA-5 or a Outlaw :wink:
  • KYFHO
    KYFHO Posts: 76
    edited June 2011
    Thanks to all for the input, it's much appreciated!
