whats a good cd or dvd player for audio
mewisemagic
was wondering is there a good cd only or even a dvd player for around $500 for playing cd's. looking to find something better than my carver tlm3600.
thanks for any info
thanks for any info
Post edited by mewisemagic on
Lots of good things are said about OPPOs, I still use Carver & Kyocera antiques and have never heard an oppo myself.
Oppo,,and Denon is in your price range,,2910,,3910.JC approves....he told me so. (F-1 nut)
what about NAD C 515BEE ?
Lot of "buzz" bout this Chinese one. Yaqin SD32A Supposed to be around your price and it sure is impressive looking at least. Why're you not getting an SD/A-490 ?
http://www.google.com/search?hl=en&source=hp&biw=1003&bih=598&q=Yaqin+SD32A.+&btnG=Google+Search&aq=f&aqi=&aql=&oq= -
Deleted
The Jolida JD-100 is a sweet CD player, its a bit over your price range ($699 thru Jolida.net) but well woth it. Replace the stock tubes with some psvane's and you will be one happy camper.
On a side note, I purchased this unit from Jolida.net about 3 months ago and I only paid $569.2-Channel System
Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
Spkrs: Tyler Acoustics Linbrook Signature Systems -
There's hundreds of them available.If you can't hear a difference, don't waste your money.
Have you ever considered a music server system? I can highly recommend a Sonos or Squeezebox as a great replacement for a CD player. Rip all your CD's to FLAC & played thru these systems is superb...you won't regret it.
Cambridge audio and NAD are both excellent "budget" CDP options....Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
