Belkin PureAV PF30 or Monster Power HTS3500MKII?
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2006
    It's a old model but still works (large enough for everything in the entertainment cabinet) APC 800RT. It got it off Ebay used not working needed batteries I believe it came with 6v 10amp batteries 4 total for 24v 10amp supply. I replaced those with 12v 7amps 4 total for 24v 14amp supply which I think was in a model 1000RT. Large UPS are a little hard to find, but a smaller one for TV and or DVR unit would be nice for anyone.
    And yes I tested it by using a Hairdryer on high.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • venomclan
    venomclan Posts: 2,467
    edited July 2006
    Sounds good. My only reservations about using a UPS with my system is that, like you said, finding a large UPS to backup the high current amps are hard to find. But additionally, constant battery replacement I am not fond of. I find that the smaller UPS's need a battery replacement every 2 years at $30 each. I do not kknow what the larger batteries would cost.
    The new Belkin flagship conditioner has the UPS in it. It is under warrenty for 3 years, while all the lower Belkin models are for life. This is due to the UPS feature. And it is $1500. Every "higher end" UPS/power conditioner I find has a 3 year warranty. I am not sure if these units allow battery replacement or if it is easy to do.
    Venom
  • disneyjoe7
    edited July 2006
    Most UPS I ever worked on have what a smaller UPS battery is 12v 7ah. So mine has 4 of these so $30 x 4 =$120...
    BTW at work is even a larger one but it needs (8) 12v 7ah batteries so $240 in batteries and very large it would be difficult to hide. So it still sits at work.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited July 2006
    Venom
    I think this due to the battery life thing. I would give them a call about batteries in the unit. But no battery a manufacture placed in an unit can't be found else where. IMHO
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • venomclan
    edited July 2006
    That is why I stick with the non-UPS models. Too much hassle for me.
  • cheddar
    cheddar Posts: 2,390
    edited July 2006
    venomclan wrote:
    Hi Crazy,
    If you budget is up to $200, than why not just get the PF60? It can be had now for around $175 and has overvoltage. I have one and I like it a lot.
    That sounds like a good deal. Where can you buy one for that price?
  • crazy
    crazy Posts: 443
    edited July 2006
    http://www.amazon.com/gp/product/B000637RN4/ref=pd_rhf_p_4/002-9784805-6504065?ie=UTF8
    This place got rave reviews on another forum
    http://www.provantage.com/belkin-ap41300-12~7BELD011.htm
    I picked up the PF30 since it was cheap! cheap! cheap! :D
    Distant Dream - A New Beginning
    www.distantdream.com
    (Now also available on iTunes)
  • venomclan
    edited July 2006
    http://www.provantage.com/belkin-ap41300-12~7BELD011.htm Now $160.00 Special Order
    http://www.thetwistergroup.com/product/AP41300-12%20D21914.html
    has them also for $319.00. I paid $194.00 2months ago from them.
    Venom
  • rskarvan
    rskarvan Posts: 2,374
    edited July 2006
    Belkin has great warranty service.... go Belkin.
  • Danny Tse
    Danny Tse Posts: 5,206
    edited June 2011
    Just want to give this thread a bump since I found the Belkin PF30 at Buy.com for $60.00 w/ free shipping....
    http://www.buy.com/prod/belkin-pureav-home-theater-power-console-pf30/q/loc/101/207514354.html
    pitdogg2 Posts: 27,045
    edited June 2011
    Danny that is a STEAL
  • stangman67
    stangman67 Posts: 2,329
    edited June 2011
    Wowzers that is a steal. I didn't notice the 30 at Buy, I just bought the PF60 from them at 150
  • pdxfj
    pdxfj Posts: 376
    edited June 2011
