Dummy Load for Amplifier Test
skrol
I am working on a Carver PM-950. It seems ok when not driven very hard. Just a slight 60Hz hum. The guy says that it starts cutting out when it gets warm. I suspect that the amp is ok and that the problem is in the mixer as it def does have some issues.
I don't want to drive it hard with any of my speakers not to mention it is too loud. Anyone have any economical ideas for making a dummy load for testing an amp?
Stan
Stan
Stan
Main 2ch:
HT:
Other stuff:
Main 2ch:
HT:
Other stuff:
Post edited by skrol on
Don't know if you are familiar with this site, but here is some good reading for ideas.
http://www.diyaudio.com/forums/parts/35050-8-ohm-dummy-load.html -
4-8 ohm resistor at 200 watt, or more, rating?
http://www.google.com/products/catalog?hl=en&q=8+ohm+resistor+200+watt&bav=on.2,or.r_gc.r_pw.&biw=1100&bih=835&wrapid=tlif130750627237810&um=1&ie=UTF-8&tbm=shop&cid=10695229063316396272&sa=X&ei=e_buTYrwKsuUtwet9aTqCQ&ved=0CG0Q8wIwAg#
http://s88932719.onlinehome.us/resistors.htmLumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I use two of these dummy loads for testing and burn-in. They work very well and are very well made. I actually ended up terminating them with banana plugs as that was easier to use. I used to solder resistors together until I had larger enough power handling, but that's a bit of work, and I would always end up loosing them; you can't loose these dummy loads as they are surprising large.
Thanks, that is some good stuff. The PM-950 is rated 325W per channel into 8 ohms, 475W per channel into 4 ohms. I can probably take one of the heating elements out of the oven while my wife is asleep:biggrin:.
I am starting to believe that the amp is fine. I hooked it up to my Denon DRA-825R pre-amp out and attached my S8's. The hum was gone and it really had a nice clean, rich, warm sound that i was not expecting from a Pro-Amp. Of course I was doing this at night while the family was sleeping so I couldn't really crank it enough to drive it hard.
Dang, I just placed an order with PE yesterday. If I added a couple of these I could have gotten free shipping.
StanStan
Main 2ch:
HT:
Other stuff:
If you REALLY want to cook, place them in a 5 gallon bucket of water & watch it boil~TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Or liquid nitrogen! -
The reality is I only have the 100w dummy loads, but have pushed them over that power limit on tests by limiting the time. If you want to push 325w into a 200w dummy load for a few seconds to get a reading, it's not going to be a problem. Just use a well designed dummy load with cooling fins and you've been fine.
