Dummy Load for Amplifier Test
skrol
skrol Posts: 3,499
edited June 2011 in DIY, Mods & Tweaks
I am working on a Carver PM-950. It seems ok when not driven very hard. Just a slight 60Hz hum. The guy says that it starts cutting out when it gets warm. I suspect that the amp is ok and that the problem is in the mixer as it def does have some issues.
I don't want to drive it hard with any of my speakers not to mention it is too loud. Anyone have any economical ideas for making a dummy load for testing an amp?
Stan
Stan
Main 2ch:
HT:
Other stuff:
  • audiobilly
    audiobilly Posts: 351
    edited June 2011
    Don't know if you are familiar with this site, but here is some good reading for ideas.
    http://www.diyaudio.com/forums/parts/35050-8-ohm-dummy-load.html
  • BlueFox
    BlueFox Posts: 15,250
    edited June 2011
  • zingo
    zingo Posts: 11,258
    edited June 2011
    I use two of these dummy loads for testing and burn-in. They work very well and are very well made. I actually ended up terminating them with banana plugs as that was easier to use. I used to solder resistors together until I had larger enough power handling, but that's a bit of work, and I would always end up loosing them; you can't loose these dummy loads as they are surprising large.
  • skrol
    skrol Posts: 3,499
    edited June 2011
    Thanks, that is some good stuff. The PM-950 is rated 325W per channel into 8 ohms, 475W per channel into 4 ohms. I can probably take one of the heating elements out of the oven while my wife is asleep:biggrin:.
    I am starting to believe that the amp is fine. I hooked it up to my Denon DRA-825R pre-amp out and attached my S8's. The hum was gone and it really had a nice clean, rich, warm sound that i was not expecting from a Pro-Amp. Of course I was doing this at night while the family was sleeping so I couldn't really crank it enough to drive it hard.
    Dang, I just placed an order with PE yesterday. If I added a couple of these I could have gotten free shipping.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • TNRabbit
    TNRabbit Posts: 2,168
    edited June 2011
    If you REALLY want to cook, place them in a 5 gallon bucket of water & watch it boil~
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • zingo
    zingo Posts: 11,258
    edited June 2011
    TNRabbit wrote: »
    Or liquid nitrogen!
  • zingo
    zingo Posts: 11,258
    edited June 2011
    The reality is I only have the 100w dummy loads, but have pushed them over that power limit on tests by limiting the time. If you want to push 325w into a 200w dummy load for a few seconds to get a reading, it's not going to be a problem. Just use a well designed dummy load with cooling fins and you've been fine.
