Yamaha RX V596
VR3
VR3 Posts: 29,432
edited June 2011 in For Sale (FS) Classifieds
In great shape - one blemish is what pictured --
Sold for 1000 new many years ago
$95.00 shipped takes it!
eatures
*INDICATES FEATURE NOT ON LOWER PRICED MODEL
5-CHNL H/T RCVR W/DOLBY DIGITAL, DTS, CINEMA DSP AND TRI-FIELD PROCESSING
The RX-V596 is a 5-channel receiver providing Dolby Digital and DTS decoding, Dolby Pro Logic processing and Yamaha's Digital Sound Field Processing, Cinema DSP and Tri-Field Processing.
BUILT-IN DOLBY DIGITAL
The most advanced and realistic encoded surround sound for movies from Dolby Laboratories. The new Dolby Digital system is a fully discrete system providing six channels of sound. Five are full-frequency channels, and the sixth is a low frequency effects channel.
BUILT-IN DTS
Like Dolby Digital, DTS is a discrete 5.1 channel system. It uses a higher bit-rate for greater resolution and is available on DVDs, laser discs and music CDs.
TRI-FIELD CINEMA DSP
Yamaha's exclusive Tri-Field Processing which applies Digital Sound Field Processing technology to Dolby Digital and DTS to create a true movie theater experience in the home. It develops independent enhanced sound fields for the front signals as well as for left and right surround.
DISCRETE POWER TRANSISTORS*
Discrete power transistors rather than IC chips are used in the amplifier section to provide the cleanest sound possible. The amp delivers 100 watts to all five channels.
NEW DIGITAL-TO-ANALOG CONVERTERS*
New digital-to-analog converters with 96 kHz/24-bit capability assure that the RX-V596 can handle all digital audio formats and data with complete fidelity.
ACCLAIMED YAMAHA IC CHIPS
Yamaha's YSS-918 chip provides Dolby Digital and DTS with full channel separation and no front-to-back bleedthrough. In addition to the chip creates Yamaha's Music and Cinema DSP and Tri-Field Cinema DSP modes.
23 SURROUND MODES INCLUDING MUSIC, CINEMA, AND TRI-FIELD DSP PROGRAMS
Yamaha's exclusive Digital Sound Field Processing for music recreates the acoustic personalities of actual concert halls and other venues, such as the Roxy Theatre in L.A., Village Gate in N.Y., Anaheim Stadium and concert halls and churches in Europe. Cinema DSP multiplies the effects of Dolby Pro Logic and Yamaha DSP to provide the best possible Pro Logic movie theater recreation in your home. Tri-Field Processing DSP does the same for Dolby Digital and DTS.
6-CHANNEL INPUTS FOR EXTERNAL DECODER
The RX-V596's rear panel has input jacks to accommodate an external 6-channel decoder. So the receiver is ready for any other 5.1 channel format, should one be developed.
THREE DIGITAL INPUTS*
The RX-V596 can accommodate three digital sources. The jack panel has three optical digital and two coaxial digital inputs.
THREE AUDIO AND 5 AUDIO/VIDEO INPUTS*
The RX-V596 is a versatile receiver incorporating three sets of audio-only inputs and 5 pairs of A/V inputs. All the video inputs have RCA jacks and 5 S-video inputs. Includes one set of A/V inputs on the front panel for fast and easy connection. In addition, the RX-V596 provides S-video and composite video output.
TWO S-VIDEO OUTPUTS
S-video output jacks for TV Monitor and VCR assure the best quality video pass-through.
AUTO PRIORITY INPUT SELECTION
When different input formats are connected from the same source, the RX-V596 automatically prioritizes them and selects in order DD, DTS, PCM, and finally the analog input.
AUTO SOUND DECODER
The RX-V596 senses a Dolby Digital or DTS signal and will automatically switch the receiver to that mode when the signal is detected.
NEW YAMAHA UNIVERSAL REMOTE CONTROL
The advanced remote control with the RX-V596 has luminescent keys and preset codes for most brands of VCRs, TVs, etc.
LOW IMPEDANCE DRIVE CAPABILITY AND IMPEDANCE SWITCHING
Yamaha's famed low impedance drive circuitry is included in this receiver so that it can handle virtually all loads and a wide variety of speakers. For further speaker matching, the receiver's back-panel switches can be set for either 4- or 8-ohm speakers.
LINEAR DAMPING FACTOR CIRCUIT
The advantage of full range, 20 to 20,000 Hz, damping is that it improves the defiition and resolution of the sound output throughout the audible frequency range.
A/B SPEAKER SELECTOR
Allows selection of either a first set of speakers or a second -- or both.
SLEEP TIMER
Permits a delayed receiver turn off. You can set it for up to two hours in 30 minute increments.
40-STATION DIRECT ACCESS PRESET TUNING
Up to 40 preset AM and FM stations can be grouped in five groups eight stations. These groupings make it easy for family members to easily access their favorite stations or to have musical genres, such as all the jazz stations, grouped together.
BINDING POST SPEAKER TERMINALS
Yamaha's heavy-duty binding post speaker terminals accept banana plugs, spade connectors, and a variety of speaker wire, including heavy gauge cable.
Specs
Specifications
Minimum RMS Output Power per Channel
MAIN, 20Hz-20kHz, 0.06% THD, 8 ohms...100W + 100W
CENTER, 20Hz-20kHz, 0.06% THD, 8 ohms...100W
REAR, 20Hz-20kHz, 0.06% THD, 8 ohms...100W + 100W
Dynamic Power per Channel
MAIN, 8/6/4/2 ohms...130/150/190/240W
Dynamic Headroom
8 ohms...1.14dB
Damping Factor
MAIN L/R, 20Hz-20kHz, 8 ohms...80
Input Sensitivity/ Impedance
PHONO MM...2.5mV/47k ohms
CD, etc...150mV/47k ohms
Maximum Input Signal Level
PHONO MM, 1kHz, 0.05% THD, (Effect on)...100mV
CD, etc (Effect on)...2.2V
Output Level/ Impedance
REC OUT...150mV/1.2k ohms
PRE OUT (MAIN
SUBWOOFER (EFFECT OFF, MAIN SP:SMALL)
MONO...4.0V/1.2k ohms
Headphone Jack Rated Output/Impedance
CD, etc, (150mV, 8 ohms)...340mV/560 ohms
Frequency Response (10Hz-100kHz)
CD, etc, MAIN L/R...+0/-3.0dB
RIAA Equalization Deviation
PHONO MM...0 +/- 0.5dB
BASS
Boost/Cut...+/-10dB (50Hz)
Turnover Frequency...350Hz
TREBLE
Boost/Cut...+/-10dB (20kHz)
Turnover Frequency...3.5 kHz
Bass Extension
+6dB (60Hz)
Filter Characteristics
SUBWOOFER OUT: LPF...fc=90Hz, 18dB/oct
MAIN, CENTER, REAR SP SMALL: HPF...fc=90Hz, 12dB/oct
Total Harmonic Distortion (20Hz-20kHz)
PHONO MM to REC OUT (1V)...0.02%
CD, etc, to MAIN SP OUT L/R (1V)...0.06%
Signal-to-Noise Ratio (IHF-A-Network)
CD, etc, Input Shorted (Effect off)...99dB
Residual Noise (IHF-A-Network)
MAIN, SP OUT...150uV
Channel Separation (Vol.-30dB, Effect off)
PHONO MM, Input Shorted, 1kHz...60dB
CD, etc, Input 5.1k ohms Shorted, 1kHz...60dB
Muting
- infinity
Video Signal Type
NTSC
Composite Video Signal Level
1Vp-p/75 ohms
S Video Signal Level
Y...1Vp-p/75 ohms
C...0.286Vp-p/75 ohms
Component Signal Level
Y...1Vp-p/75 ohms
Cb/Cr...0.7V/75 ohms
Video Maximum Input Level
1.5Vp-p
Video Signal-to-Noise Ratio
50 dB
Monitor Output Frequency Response
Composite Video Signal...5Hz-10MHz, -3dB
S-Video Signal...5Hz-10MHz, -3dB
Component Signal...DC-30MHz, -3dB
Tuning Range
530 to 1,710kHz
50dB Quieting Sensitivity (IHF, 75ohms)
Mono (1kHz, 100% Mod)...1.6uV (15.3dBf)
Stereo (1kHz, 100% Mod)...23uV (38.5dBf)
Selectivity (400kHz)
75dB
52dB
Harmonic Distortion
Mono/Stereo (1kHz)...0.1./0.2%
Stereo Separation
1kHz...48dB
Frequency Response
20Hz-15kHz...+0.5/-2.0dB
Output Level
AM 30% Mod. 1kHz...150mV
Antenna Input
75 ohms unbalanced
Usable Sensitivity
300uV/m
Antenna
Loop Antenna
Dimensions
Width = 17 1/8 in.
Height = 5 15/16 in.
Depth = 15 3/8 in.
Weight
25 lbs.
Comes with remote
Post edited by VR3 on
    VR3 Posts: 29,432
    edited June 2011
    Just received a pm -
    Giving dibs to the gentleman for 24 hours
    Thanks :) - Will keep thread updated
  • Conradicles
    Conradicles Posts: 6,343
    edited June 2011
    I had one similar and thought it was a great amp.
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2011
    I'd suggest someone pick this piece up as it's a great deal on a feature packed AVR.
    VR3 Posts: 29,432
    edited June 2011
    Thanks Mark
    I had a Yamaha receiver back in the day - it was my first receiver... good nostalgia! :)
    VR3 Posts: 29,432
    edited June 2011
    I will throw in a set of component cables and RCA cables... and maybe some other cables...
    Just want this out of my den!
    Thanks guys! :) xoxo
    (Gentleman PMd me back and said he had to have HDMI)
    VR3 Posts: 29,432
    edited June 2011
    Bump
    VR3 Posts: 29,432
    edited June 2011
    Just to spell it out for those that dont want to read the descript...
    PREOUTS, DTS, DD all for under a Benjamin!
    VR3 Posts: 29,432
    edited June 2011
    I actually hooked up a local bud who has a baby on the way. Hooking it up tomorrow
    Sorry man, thanks for the bump
    VR3 Posts: 29,432
    edited June 2011
    Just got through getting this hooked up at my buddies and it RIPS.
    Tooo cool.
    I got him hooked up with the following setup -
    Mains - RT55
    Center - RT3 bookshelves powered by an Audiosource amp
    Surround - Polk M2?
    Sub - Polk PSW150
    This receiver
    Its pretty sweet
  • 20hz
    20hz Posts: 636
    edited June 2011
    I hada early yamaha avr (non digital) I used it for 5 years than set it up at a buddyies its still going strong , another avr he plugged his MK sub into the switched ac lead (it drew way to much power in that outlet) but it did work for 2 years before something died .
    I wish I bought a new yamaha avr but got a good deal on a sony es .
    I recomend yamaha to anybody .
