Power Conditioners/Power Plants
dei08dei
dei08dei Posts: 29
edited June 2011 in Electronics
I read a lot of advertisements where manufacturers say you must have clean, noiseless AC going through your system for the best sound possible. Their Power Conditioners, Power Plants, etc will do just that for a cleaner sound you will be able to actually hear. (It sounds like those power cord claims ). Has anyone stumbled onto something that REALLY works? Is there products out there that you can actually hear a difference that do not cost $$$$? Or do we wish we could hear the difference?
Post edited by dei08dei on
    treitz3 Posts: 19,966
    edited June 2011
    Not really....at least in my experience. I wish in crystal clear after thought that I had spent that money on a dedicated line instead. YMMV as well as others. This is just my experience with them.
  • dei08dei
    dei08dei Posts: 29
    edited June 2011
    I did the power cord thing. The manufacturer said "money back" if I did not hear a difference. I did not. I did get my money back. I wonder if it depends on the quality of your gear (high end vs low end)?
    edited June 2011
    Yes. It can depend on many factors besides just the quality of your gear.
  • dkg999
    dkg999 Posts: 5,647
    edited June 2011
    In my apt bldg with old circuits and old transformer boxes on the entrance wiring using Tripplite and Panamax power conditioners did remove significant noise that was coming through in both the audio and video. I don't have the option to run a dedicated line with whole house or circuit specific power surge and voltage level protection, so my answer is yes they can make a difference.
    DKG999
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited June 2011
    I have used Balanced Power Tech with good results. Not overly high priced and a noticable improvement for sound and picture quality. I guess it also depends on how dirty your power is though.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • cheddar
    cheddar Posts: 2,390
    edited June 2011
    In my experience you can see it before you can hear it. A power conditioner helped with the TV when I had some bad power in the house. Though I wasn't really having any problems with the audio. Anything audible on your line already? Or are you just going for diminishing returns for that last extra bit of quality? I think that last bit is where the YMMV comes in to play.
  • gp4jesus
    gp4jesus Posts: 2,016
    edited June 2011
    "...YMMV"
    What does this mean?
    *all connected w/Premiere ICs
    edited June 2011
    Your mileage may vary.
  • boomerfss
    boomerfss Posts: 125
    edited June 2011
    I found a difference in quality, but I believe it is because my house is 50 years old. I would think there would be less of a difference in a new house.
    Onkyo HTRC 180
    Polk Monitor 70 Series 2 Fronts
    Polk CSi A6 Center
    Polk PSW505 Sub Woofer
    Polk Monitor 60 Series 2 Surrounds.
    Harman Kardon HTSK18 Back Ceiling Mounted
    PS3 Xbox
  • Geoff4rfc
    Geoff4rfc Posts: 2,817
    edited June 2011
    cheddar wrote: »
    I can relate to this statement. I bought a tripplite 10 plug bar, never did notice any audio improvement (didn't expect anything except to have a quality power strip for my gear), but my plasma got a little cleaner looking. My wife that notices NOTHING came in and asked me what I did to the tv to make it look so nice.
    And when I say nothing, I moved my 30's from surround on the wall above our heads (bedroom) and put them on the wall next to the plasma (height channels), and moved the 40's from the upper corners of plasma wall to the surround position.
    That change had been there for a week and a half, and my wife looks at the 30's and asked, "When did you get those speakers?"
    The 30's were the first pair of Polks I ever bought.......:biggrin:
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • dei08dei
    dei08dei Posts: 29
    edited June 2011
    Reason I am asking is because I am always tinkering. I made some speaker wires using Blue Jeans Canare 4S11 Cable based on slammin86 great post. I was concerned about shielding so I decided to add my own shielding in the form of aluminum foil (wrapped twice around the cable and then covered with tightly wrapped electrical tape). I then covered the cable with gray Techflex.
    When I first tried the cables, I immediately noticed more base. They may sound clearer, but that is probably my immagination. It is still fun to tinker. So I am wondering what next.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited June 2011
    I posted the same question ages ago and was slammed w/ yes you a power conditioner if your your in a lightening prone area or or electric is old enough to be aluminum or just a cluttered mess. For the longest time I was looking for an Adcom ACE515 conditioner which would fit nicely into the rack I have. Instead I got a Samson ps15 8 outlet surge pro but the joule protection just isn't there. I think all it is a nicelooking plug rack. And one other observation,I've noticed on e-bay that there are hundreds of Monster conditioners at all prices.From strips to huge powercenters.
