Question for the experts...
steveinaz
steveinaz Posts: 19,546
edited February 2012 in The Clubhouse
How come this forum won't let you change the topic line of the first thread, if you're the author? For instance, it would be cool in the Flea Market if you coul add "SOLD" after your topic line:
"For Sale: 57 Chevy...SOLD"
It does change it "inside" the thread, but the main board still shows the original topic line...
Post edited by steveinaz on
    F1nut Posts: 52,301
    edited March 2004
    Talk to Justin, he's in control.
  • steveinaz
    edited March 2004
    Justin, can you fix this? The XM Radio forum uses the same software and allows the author of the thread to change the topic line....
  • Frenchquartr
    Frenchquartr Posts: 1
    I have a PSW 202 Sub that wont work since my daughter cranked it up while I was away. Is there a fuse or something I can change to make it work again?
  • Systems
    Systems Posts: 14,872
    My question is, what are you asking for the '57 Chevy Steve?
    Testing
    Testing
    Testing
