My SDA 1B's
renowilliams
I made a video today of my 1B's in action
http://www.youtube.com/watch?v=cHSOEUNSwsk
I'm still looking fora pair of 2.3's near me but I do like these speakers.
"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Bluray: Oppo BDP-93
Post edited by renowilliams on
Wow, those sound great through my Klipsch computer speakers :cool:.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
I have a pair also with 194's. have been thinking of doing the xovers have you?if so what parts did you use?
I havn't yet. but I probably won't, looking for 2.3's"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Bluray: Oppo BDP-93
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
Re-capped and repaired my 1Bs perhaps a year ago. I'm TOTALLY THRILLED with the result.I have a pair also with 194's. have been thinking of doing the xovers have you?if so what parts did you use?
I followed the thread started by inspiredsports pioneering the 198 tweets in the 1B/SRS 2 blade/blade speakers. (Replace the 4.4uf capacitor with a 5.8uf cap on each HF board, and buy four RDO 198s.)
Beyond that, I used inexpensive film caps and non-inductive resistors. If I were doing it again, I would absolutely use the Mills brand resistors as their physical size is smaller than what I bought.
Dayton 1% caps for the HF circuit board
Removed the polyswitches and did NOT add additional resistance to compensate.
Dayton 5% caps and Erse PulseX 3% caps for the LF circuit board.
Have not changed inductors. Don't have any real urge to, either; although some folks that have upgraded the inductors wax poetic--and I wouldn't deny the possibility of sonic improvement.
Two photos of the LF board components. Not sure I have decent photos of the HF boards.
Also installed damping material on the MWs and passives; and attached them to the cabinet with rope caulk instead of the OEM gaskets. Had a defective tweeter so they certainly weren't sounding their best before the project started, but I sure am lovin' them now.
Also did an internal wiring bypass to allow for future AI-1 use; but I'm no electrical engineer and that mod did not work out as well as I might have hoped. I can use either the original blade/blade interconnect (sounds great) or the single-conductor-with-ground interconnect (sounds less than great, but not hateful.)
Clearly, you'd not need to include this mod.
