Why are most PS3 games 780p?
blueboxer
blueboxer Posts: 621
edited June 2011 in Video Games
Just noticed that almost all of my PS3 games are limited to 780p, I thought this was really odd considering one of the main selling points of the PS3 is its blu-ray capabilities. Seems really odd to limit their games to 780p and dolby digital. Are these just the older games or did I miss something?
Post edited by blueboxer on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,722
    edited June 2011
    I've never heard of 780P, so you've got me there.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited June 2011
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited June 2011
    Its 720p. My call of duty black ops is 1080p. Some are some aren't.
  • bobman1235
    bobman1235 Posts: 10,822
    edited June 2011
    Yeah, they should really update to 1020i.
    /snark
  • GoBigBlue
    GoBigBlue Posts: 212
    edited June 2011
    It's the developer's choice to go either 1080p or 720p - my guess is to save on time and money.
  • kuntasensei
    kuntasensei Posts: 3,263
    edited June 2011
    blueboxer wrote: »
    It's because despite the power of the Cell processor, the RSX chipset from Nvidia wasn't exactly "cutting edge" when they implemented it. With all the consoles, they have to make tradeoffs depending on their available CPU/GPU budget. In many cases, developers can either do 1080p with minimal anti-aliasing or 720p with 4x AA, which may look better, for example. It's up to the individual developer to decide how to use the available power so the game looks its best.
    Xbox 360 is no different, except it has a dedicated scaling chip that lets them output 1080p even if the game itself is internally rendering at 720p or lower.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • cheddar
    cheddar Posts: 2,390
    edited June 2011
    blueboxer wrote: »
    Seems really odd to limit their games to ... dolby digital.
    Several games support 7.1 uncompressed PCM which is basically lossless since it isn't compressed in the first place with Dolby or DTS.
  • blueboxer
    edited June 2011
    My bad, sleep depravation has gotten to me, but thanks for an actual answer. I just assumed that putting out 1080p on a blu-ray movie would require the same processing power as a video game. I do notice a improvement whenever Dolby HD is available, but think I still rather buy a title offered for both consoles for my 360.
  • jbooker82
    jbooker82 Posts: 1,627
    edited June 2011
    So wouldnt that be the same thing as playing a 720P ps3 game and having my onkyo avr upscale it to 1080P? The xbox is just upscaling it before it hits the avr or tv.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • Joe08867
    Joe08867 Posts: 3,919
    edited June 2011
    720 721 whatever it takes.....
  • kuntasensei
    edited June 2011
    jbooker82 wrote: »
    Yes and no. The Xbox 360 does some post-processing/AA in the scaler chip that can often make games have less jaggies than if they were just upscaled directly in your display or AVR. For the most part, the differences would be subtle, but a lot of times when you see those silly comparisons of the same game on PS3 and 360, that scaling and processing is what makes it appear that the 360 has the smoother picture even if both are rendered at the same resolution internally. Either way, no big whoop... Both consoles rarely render directly to 1080p, so you're scaling it somewhere in the chain no matter what.
    Equipment list:
    Emotiva XPA-3 amp
  • cheddar
    edited June 2011
    blueboxer wrote: »
    Actually playing a blu-ray is much easier on the ps3 than playing a video game. The 1080p video off the blu-ray is pre-rendered and the ps3 just has to display what it reads. Video games change as the game is played. The ps3 first has to calculate the changing game state (as a player moves around and shoots things for example), then it has to calculate how to graphically represent it, then it displays it.
    All those extra game capabilities make the ps3 overengineered as a blu-ray player and that's why it was firmware upgradable to keep it current with dedicated players all these years.
