Got a new Mac!
Serendipity
Have to say...
Pandora streaming over the whole-house audio system is AWESOME!
Now I have one question for the experts - which would provide the best sound quality?
MiniDisplayPort --> HDMI --> Sony KD-34XBR960 (using TV as a DAC)
Then the Sony KD-34XBR960 analog out L/R to the whole-house audio stack?
Or should I use the analog audio connection (using the sound card DAC) to feed the whole house audio system?
Thanks!
Thanks!
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
I would use the audio connections on the Mac, Maybe? Are they separate RCA's Or what?
If not then use the Sony. I would look into a separate DAC for the future.. -
Right now I am using the TV as the DAC and it sounds great!polkaudio RT35 Bookshelves
How are you getting audio out of a video only port?If life had more tubes it would be a lot smoother.
I can't help with connection advice, but your set-up sounds like an awesome new toy!
Can you pause the stream of the music as you walk from room to room like the Netfix commercial does with movies?Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's -
If he is using air play then could walk from room to room and control all of his music or videos from an any i fill in the blank device.If life had more tubes it would be a lot smoother.
Which Mac did you buy Alex?
