OK, next question
ux4it
ux4it Posts: 9
edited May 2011 in Speakers
So, after having such a great response from my last question, I thought I'd ask another.
Currently, I am running Monitor 70's for my mains, monitor 60's for my rears, and my new CS2 for my center channel. I would like to replace my existing sub(klipsch HTIB) with a good matching Polk sub.
Any recommendations out there.
I am running all this on a Denon AVR-891.
My HT room is not that big, but I am looking for a great sounding sub.
Thanks in advance.
Post edited by ux4it on
    treitz3 Posts: 19,950
    edited May 2011
    Hello and welcome to the forum. Do you have a budget in mind?
  • ux4it
    ux4it Posts: 9
    edited May 2011
    Price would be somewhat of a factor. But, I'm looking at spending up to 6 or 7 hundred.
    When I can get the money together.
    edited May 2011
    Welcome to Club Polk!
    Here's a sub in your range that would go well with your set up and give you a lot of HT slam!
    http://www.epiksubwoofers.com/legend.html
    cnh
  • PrazVT
    PrazVT Posts: 1,607
    edited May 2011
    what cnh said.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • ux4it
    ux4it Posts: 9
    edited May 2011
    I checked out that sub like you suggested. Looks like they don't ship to Canada where I live. I will do some poking around and see what I can find for a Canadian distributor.
    I am kind of partial to Polk though.
    EndersShadow Posts: 17,687
    edited May 2011
    ux4it wrote: »
    newegg.ca.com
    Check out the PSW505 or if they carry the DSW line. Those are about the only polk subs we (or at least I) would recommend.
    edited May 2011
    The PSW505 is certainly 'the' value Polk sub. But if you have the money I'd go with this:
    http://www.polkaudio.com/homeaudio/dsw/index.php?s=dswpro600
    if you want a good current Polk sub. Not sure what that would cost in Canada though?
    cnh
  • Almadacr
    Almadacr Posts: 185
    edited May 2011
    cnh wrote: »
    cnh
    I second this but i would had 2 of them :biggrin: but if you want to buy in Canada you have SVS but more expensive the only bang for the buck is Velodyne .
