OK, next question
So, after having such a great response from my last question, I thought I'd ask another.
Currently, I am running Monitor 70's for my mains, monitor 60's for my rears, and my new CS2 for my center channel. I would like to replace my existing sub(klipsch HTIB) with a good matching Polk sub.
Any recommendations out there.
I am running all this on a Denon AVR-891.
My HT room is not that big, but I am looking for a great sounding sub.
Thanks in advance.
Thanks in advance.
Post edited by ux4it on
Hello and welcome to the forum. Do you have a budget in mind?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Price would be somewhat of a factor. But, I'm looking at spending up to 6 or 7 hundred.
When I can get the money together. -
Welcome to Club Polk!
Here's a sub in your range that would go well with your set up and give you a lot of HT slam!
http://www.epiksubwoofers.com/legend.html
what cnh said.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
I checked out that sub like you suggested. Looks like they don't ship to Canada where I live. I will do some poking around and see what I can find for a Canadian distributor.
I am kind of partial to Polk though. -
newegg.ca.com
Check out the PSW505 or if they carry the DSW line. Those are about the only polk subs we (or at least I) would recommend."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
The PSW505 is certainly 'the' value Polk sub. But if you have the money I'd go with this:
http://www.polkaudio.com/homeaudio/dsw/index.php?s=dswpro600
if you want a good current Polk sub. Not sure what that would cost in Canada though?
I second this but i would had 2 of them :biggrin: but if you want to buy in Canada you have SVS but more expensive the only bang for the buck is Velodyne .Welcome to Club Polk!
cnh
