Looking for a few impression/opinions
Geoff4rfc
Geoff4rfc Posts: 2,839
edited May 2011 in Speakers
Budgets are a pain when you're on one, I'm on one :biggrin:
I'm in a position to pick up a pair of RTiA9s but not the matching CSiA6.
I currently have a CS2. Should this do the job for now (with some tweaking) until I can pick up the new center?
Set up:
Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
Post edited by Geoff4rfc on
  • Upstatemax
    Upstatemax Posts: 2,738
    edited May 2011
    The CS2 should be fine for now.
    Upgrade as you can. :cool:
  • Geoff4rfc
    edited May 2011
    After 60 views and one reply, I can take that to mean only one thing, ALL are in agreement. I was hoping for few to chime in for some "averaged" reassurance but I guess it's not to be.
    Thanks Upstate for the encouragement. I suppose I'll find out soon enough how the three will blend together. They'll be running off the XPA-3 so should be able to get 'em dialed in good enough until I can add the matching center. No sweat.
    Set up:
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited May 2011
    Go for it, you can get the matching center at a later date.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • piker
    piker Posts: 101
    edited May 2011
    I'm sure it will work alright for temporary use. I'm guessing most people haven't tried that combination before, and so that's most likely why there isn't much to be said about it yet.
    Can you let me know what you think of the upgrade over the M70's once you get the A9's? I was looking at upgrading to 7's or 9's in the future anyway. I decided to go with the XPA-5 amp first. Speakers will come later.
    AVR: Onkyo TX-NR808
    Amp: Emotiva XPA-5 200 watts x 5
    Fronts: Polk Monitor 70 Series II
    Center: Polk CS2 Series II
    Surrounds: Polk Monitor 70 Series II
    Sub: HSU VTF-2 MK4
    HDTV: 73" Mitsubishi DLP-73740 3D-ready
    PS3, 2x XBOX 360, Wii U, Gaming PC.
  • TouchOfEvil
    edited May 2011
    piker wrote: »
    I have ran a CS2 with my A5's for at least 2 years now. It blends in just fine and honestly i see no point in getting a new center as like i said it blends no problem with the rtia line.
    If he wants to change it out later thats just as good but not a MUST.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • packetjones
    packetjones Posts: 1,059
    edited May 2011
    Yeah it will work no problem. Most have prob never heard that combination so cant really comment. It will be fine for as long as you like it.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • zx_toth
    zx_toth Posts: 417
    edited May 2011
    I ran my Lsi 25s without a center for a while and the left and right blended so well that it sounded like there was a center. If you are unhappy with how the CS2 mixes with the Rtis then try it without and see if you are happy with that as an interim solution.
    When I did get the LSiC I did note an improvement having only the two towers in the front stage but it worked nicely nonetheless while I saved for the center speaker.
    Z
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited May 2011
    Nope, there's no possible way that it will work. The two speakers will cancel each other out and create the phenomenon that's known as reverse noise.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Geoff4rfc
    edited May 2011
    Awesome curt, now I can go hang myself :biggrin:
    Set up:
    treitz3 Posts: 19,992
    edited May 2011
    Damn, I know some folks who could use one of those speakers for their wife. Gives a whole new meaning to the saying, "Honey, could you grab me the remote".
  • nwohlford
    nwohlford Posts: 700
    edited May 2011
    I did sort of the opposite recently. I have a pair of RT1000p mains that I added the CSiA6 to (the old center had died a while ago). I got a great deal on the CSiA6 ($150), and I figured I would update the mains soon anyway. If I A/B the center and the mains, the treble sounds very different, but I think they sound fine together (I don't really do a lot critical listening in room - mostly just watching TV).
    As others said, give it a chance and see how you like it.
