cs20
Just got the cs20 and tsi300s. What is the best location for the center speaker. The cs 20 is big and would fit better on the cabinet above the tv.
Post edited by LukeBrown on
Go for it. I've got a CS2, same size I believe and have mine mounted above my wall mounted 50". I had to fasten a homemade shelf, but works out great. -
You can put the Center either above or below (the reason it's arches is that you can point it upwards when it's below)
