cs20
LukeBrown
LukeBrown Posts: 2
edited May 2011 in Speakers
Just got the cs20 and tsi300s. What is the best location for the center speaker. The cs 20 is big and would fit better on the cabinet above the tv.
Post edited by LukeBrown on
  • Geoff4rfc
    Geoff4rfc Posts: 2,961
    edited May 2011
    LukeBrown wrote: »
    Go for it. I've got a CS2, same size I believe and have mine mounted above my wall mounted 50". I had to fasten a homemade shelf, but works out great.
  • mstum
    mstum Posts: 17
    edited May 2011
    You can put the Center either above or below (the reason it's arches is that you can point it upwards when it's below)
