PSW505 Available!
jpena53
jpena53 Posts: 68
edited May 2011 in Speakers
Get them while they are hot!
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290130&Tpk=82-290-130
They are 230. I would have posted this in the For Sale section but I wasnt allowed too due to my post count. Haters :( haha
I just bought a PSW111 on Tuesday too. It has not even arrived yet, now I need to sale it.
Fronts: Monitor 20s
Center: CS2
Rear: Monitor 30s
Sub: PSW505
AVR: Pioneer VSX-521K
My first true audio setup :smile:
Current Upgrade Plans
Fronts: Monitor 70s
Center: CS2
Rear: Monitor 50s
Sub: PSW505
AVR: ???? No idea yet
Post edited by jpena53 on
  • 67jason
    67jason Posts: 57
    edited May 2011
    I was just coming here to post the same thing......
    yeah newegg has the 505 back in stock:biggrin:
  • jpena53
    jpena53 Posts: 68
    edited May 2011
    Yeah I waited until I bought it before I posted here since I was scared they would sell out. Now I sort of have a problem. One too many subwoofers.
    Fronts: Monitor 20s
    Center: CS2
    Rear: Monitor 30s
    Sub: PSW505
    Fronts: Monitor 70s
    Center: CS2
    Rear: Monitor 50s
    Sub: PSW505
  • ranger
    ranger Posts: 50
    edited May 2011
    Can this sub compare to an Epik Legend? The 505 seems to have a lot of admirers.
  • jpena53
    jpena53 Posts: 68
    edited May 2011
    Haven't heard either one but yes it does. Heard it was the best PSW sub.
    Fronts: Monitor 20s
    Center: CS2
    Rear: Monitor 30s
    Sub: PSW505
    Fronts: Monitor 70s
    Center: CS2
    Rear: Monitor 50s
    Sub: PSW505
  • Upstatemax
    Upstatemax Posts: 2,800
    edited May 2011
    I have serious doubts the PSW505 is really going to stand toe to toe with an Epik Legend.
    The Legend is designed to be faster and more accurate. It can handle HT and music duty. I find I like sealed subs FAR more than vented ones and the Legend is a sealed design that diggs deeper than the 505...
    The PSW505 is a great sub for the money, but the Legend is one tough sub to beat.
  • 67jason
    67jason Posts: 57
    edited May 2011
    ranger wrote: »
    No.
    The 505 is one of the best subs at the $200 or so price point and holds its own to a point. It gets pretty low, around 23Hz if I remember correctly and is a very musical sub. Works pretty awesome for HT too. However it cannot stand up to the epik or most other internet direct subs. It is the best PSW series sub and will spank the rest of the psw line up all day and twice on sundays. Folks on a budget should definitely check this sub out.
    The most comparable competitor to the 505 is the Bic F12. A lot of folk consider the bic to better for HT over the 505...and there is likely a certain amount of validity to that statement, but I think the 505 is better musically. And since my set up is about 50/50 HT and music I went with the polk and am very happy I did. Some day I will try different/better subs, but for now the 505 is where its at for me.
    The newer polk DSW subs are supposed to a might better then this one too, but I havent heard one yet, let alone afford one at the moment.:frown:
    Im runnin 2 505s in conjunction with my monitor 70s, 60s and cs2 and I love it...even more so when I figure what it cost me for my set up.:biggrin:
  • PrazVT
    PrazVT Posts: 1,607
    edited May 2011
    I just finished helping a family member install a new HT w/ an Epik Legend and compared to my 505, it's a lot more accurate and sounds significantly better with music - even at low volumes. The 505 hits as hard, but the Legend is just more controlled - and I think the sealed design helps.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
