Help with Thiels
cstmar01
Anyone here have experience with the Thiel CS2?
http://wausau.craigslist.org/ele/2384317187.html
some popped up in my area for 150.00 bucks and if they are good I can run over and try and grab them.
Never heard Thiel's outside of being at a store and very limited experience with them.
Post edited by cstmar01 on
Grab em.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
What he said.
Ruthlessly flat and coherent. It takes awhile to get used to them, because of that.
My brother has a set like these, i think they need an external equalizer to work right... A lot of the used speakers don't have them cause they tended to fail and the speakers sound liek crap without it... you can find the thiel equalizers ocassionally on ebay.
Grab them now.....
I have a pair. Get them ****, you can thank me later
told him have cash in hand and would like to meet tonight. Now just to see if he responds.
The EQ is for it's big brother the CS3.5 only.i think they need an external equalizer to work right..
A working pair of CS2's for a buck fifty is a no brainer. -
Ruthless is a good way to describe the characteristic Thiel sound, all righty.
Atleast thats how they sound to the Fullrange guys when they are exposed to that extra top octave.:biggrin:mhardy6647 wrote: »Ruthless is a good way to describe the characteristic Thiel sound,
Actually later generations lean even more to the analytical side. -
Amen to that....grab those suckers.HT SYSTEM-
lsi 9's -
Some are more aggressive than others, fo sho; and I am not, in full disclosure, an expert on all of the Thiel models throughout their long history (ironically enough, I was more of a Polk Audio fan, back in the day).
EDIT: all that being said, I'd definitely recommend a listen before plunking down cold, hard, filthy lucre. -
The price looks good, and btw, that ads pic make me think this is a dealer of old things selling them. In other words, deal with him after a listen, put 6 $20's in your right pocket and a $20 and a $10 in the left. If you like the sound offer the $120, wave it under his nose hehe! That would be a steal!!Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
Well the guy is about 45 mins away from where I live and I'm stuck at work for another hour or two and he sent me an email that another guy was coming to look at them tonight and was also highly interested.
Hopefully he doesn't take them but if he does then he does. I wanted to meet yesterday but didn't work for him I guess :frown: -
Guy didn't pick them up so they are still around. I'm meeting him Thursday any one know the size of these things? I want to drive my car up 2004 grand am 4 door and put them in there if possible.
39" h ,the base of the cab is 12"x12" .
Why don't you pick them up already? Don't make me make a road trip.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
well I haven't gotten them yet as I'm limited for time and so is he. With being over 45 mins away and telling me that I have to be there before 6 and I get done with work at 5 (then rush hour out of our little city) today is a no go. I'm not going to lose my job over speakers....
so just got them home and hooked up. Played some Dire and some other things I'm familiar with. They imaged very very well, and are very netural. However do lack in bass compared to the Amazings but that is an easy given. I like them.
Also it was cool as the guy also has a set of Vandys, MMGs, Carver Amazing III, some yahama that uses some beryllium drivers, a crap ton of old receivers, and some tube stuff. He told me I'll be the first on his list if he has to sell more as his wife told him he had to get rid of stuff.
They are in good condition for being so old. One of the dust caps fell off and someone glued it back on (terribly), and some dings here and there, nothing major. There are some dents in the tweeters but work like normal.
SO now that I bought them, what the heck do these normally go for used?
Also do they favor SS or tubes, as I would be tempted to make a tube system with them, nothing uber expensive but something nice. -
They appear to be a pretty benign impedance curve, any tube amp capable of a 6ohm load will be fine.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Theils do image well,they will attribute much of that to their use of a phase accurate(minium phase change) 1st order crossover.As for the bass response that Vifa P21 will reach into the low 40's.
On the woofer or midrange?If the midrange a wonky dust cap may cause some anomalies at the upper end of its operating range.On the woofer it might be prone to vibration if not bonded to the cone properly.One of the dust caps fell off and someone glued it back on (terribly)
No rips in the dome?There are some dents in the tweeters but work like normal.
In pristine shape about $50.:eek::biggrin: J/k I think you did fine.SO now that I bought them, what the heck do these normally go for used? -
On the woofer or midrange?If the midrange a wonky dust cap may cause some anomalies at the upper end of its operating range.On the woofer it might be prone to vibration if not bonded to the cone properly. No rips in the dome?
the woofer and the cap is glued very tightly back on, only thing was that it just looks very bad as there is a lot of extra glue around the outside that just looks terrible but sounds fine.
The tweeters have no holes or rips. Just a few little dents but sound just fine.
Honestly I like them. They are different than the Amazings which I like and don't think they'll be going anywhere anytime soon. -
Cool as long as it is not loose it should have no audible effect.And to clarify it's a SEAS P21 not Vifa.The midrange is sourced from Vifa.the woofer and the cap is glued very tightly back on, only thing was that it just looks very bad as there is a lot of extra glue around the outside that just looks terrible but sounds fine.
Those tweets are the venerable Dynaudio D28AF's which were considered one of if not the best dome tweeter available at that time .The tweeters have no holes or rips. Just a few little dents but sound just fine.
