Subwoofer Cable
jpena53
jpena53 Posts: 68
Hi,
I am new still and I have trying searching on multiple site but I feel like I need some reassurance from the people that know best here :)
I have a pioneer vsx-520-k and I am buying a PSW111 hopefully today and I was wondering if I can use any old regular rca cable. If I can, does it matter which color I use to connect it such as red, white, or do I have to use the yellow cable. I want to hook it up with LFE
I am looking at a cable from Monoprice but I want to hook up the sub tonight if I do get it since I have some rca cables lying around. I want to watch Saving Private Ryan in full 5.1 blu-ray glory :)
Fronts: Monitor 20s
Center: CS2
Rear: Monitor 30s
Sub: PSW505
AVR: Pioneer VSX-521K
My first true audio setup :smile:
Current Upgrade Plans
Fronts: Monitor 70s
Center: CS2
Rear: Monitor 50s
Sub: PSW505
AVR: ???? No idea yet
Post edited by jpena53 on
  • codyc1ark
    codyc1ark Posts: 2,537
    edited May 2011
    Hello!
    It won't matter which color you use at all. I've got a couple of monoprice 'sub' cables, and they do work great. For the price you may want to order a long one if you can accomodate your sub near you, to see if you like that placement better. Placement with subs can make a break them sometimes, so play around with it. Good luck!
    -Cody
