Digital Coax or analog connection
rpalme1
For music which would be better? Is there any noticeable difference? I have an Onkyo DVD/CD 5 disk and Pio 1120 reciever. Thanks for any help..
Post edited by rpalme1 on
If you want multi-channel audio (for DVDs), then the digital cable. For strictly 2-channel, stereo music (regular CDs), it probably doesn't matter a whole lot which one you use. It only changes where the digital to analog conversion takes place, so whichever sounds best to your ears is the better one.
Thanks for the reply.. If I use the Digital Coax I'm using the DAC in the cd player. If I use analog cables I will be using the Pio. Dac correct? Sorry for all the questions I'm still learning.
I think I will keep using my Music Streamer 2 off my computer and not worry about it.
You have it backwards.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
You got it backwards;
If you use a digital coaxial cable, you will be using the receiver's built-in DAC to do the digital to analog conversion because you're sending a digital signal from the disk player to the receiver for the receiver to convert.
Using analog cables means the disk player will do the conversion from digital to analog because the signal being output through the analog cables is just that, analog.
To better help you make a decision, use a set of 'quality' cables (whatever that means to you) and compare both analog and digital signals coming from your player.
My assumption would be that the Pioneer would have the better DAC, but again that's just an assumption.
-FreddyTruck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Umm....he has it backwards
2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Lol.....Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Just said that while I typed everything else out lol
Yes. I was getting ready to eat dinner, so short and to the point. :biggrin:Lumin X1 file player, Westminster Labs interconnect cable
What's for dinner? I'm craving thirds....Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Try in both ways for a full week at a time (or more), and decide for yourself. Don't try to A/B it, the changes are likely far too subtle.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I tried both and really couldn't hear a difference between the two. I went with the digital cable because it has a sturdier connection than the optical cable.
HTH -
Thanks for the help and setting me straight.
