Cable Length
audiocr381ve
My wife and I changed our room setup yesterday which serves as the living room, baby play room, and my 2 channel audio sanctuary (scary combo, I know). Anyway, the way we have it setup now is the best way to utilize the space as such.
Here's the problem (not sure if it's a real problem yet). I ordered 22 feet of Canare 4S11 from Blue Jeans Cable to make an 11 foot pair, but that was for the old living room setup! For my left speaker, from amp to speaker it measures about 12 feet.
This probably isn't a big deal, but my OCD is just kicking in strong. I'm okay having one speaker cable about 2 feet longer than the other right?
Post edited by audiocr381ve on
audiocr381ve wrote: »I'm okay having one speaker cable about 2 feet longer than the other right?
Yup, no issues"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »Yup, no issues
GOOD news, thanks man. -
I agree, you're just fine.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
186000 Miles Per Second: Not Just a Good Idea, it's the Law
But my ears can detect that
Great, thanks guys. These are the ones that I'm going to make "pretty." I have some Techflex, heat shrink, and banana plugs coming tomorrow
Why did you order exactly the amount of cable you needed? Why not order 2-3 feet more? You know just in case?
To answer your questions, you don't really specify what kind of receiver you have but most new receivers have distance measurements as part of the speaker setup and the receiver adjust according to distance from speakers to listening location.
Something else to consider is some speakers are hard to place, especially if they are too wide apart. I have found this to be the case when I used to have bookshelf speakers. If they are tower then 8-12 feet apart is very common. I think you should be ok.Current HT setup
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
Sub: Velodyne DLS-3750R
Receiver: Pioneer SC-07
Amplifier: Sunfire TGA5200
TV: Sony KDS60A2020
DBP: Sony DBP-S350
CDP: Pioneer DV-48AV
Interconnect cables: SignalCable analog II
speaker cables: SignalCable Ultra Speaker Cables Bi-wire -
I actually ordered 4-6ft more than I needed, but like I said in my original post, we changed the layout of our living room last night.
I don't have a receiver, I'm running separates.
Placement was definitely an issue. I had to make compromises here for the better of my family since it is a heavily shared space (11 month old in the building!).
Thanks for the input! -
If you are that OCD about cable length, you could always make both cables the same length, and then run the shorter distance out and back to cover the slack. This is what I've always done as I like symmetry. :cool:
While true, that has nothing to do with the length of speaker wire to the speaker. The AVR delays the signal to each speaker based on the measurement setting from the speaker to your chair, and, ideally, the end result is the sound reaching your ears from all speakers at the correct time.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
What would the speed of light in free air have to do with the topic at hand??186000 Miles Per Second: Not Just a Good Idea, it's the Law
The issue here is the interface between an active electronic output device and a motor hung at the other end of the wire. So propagation down a wire is only one part of the situation.
The answer is with different lengths of wire that there will be a difference in the characteristic sound. The question is....do you hear it? Do you hear the difference in the final frequency response due to the impedences and the characteristic timing changes (dependant on frequency), the dampening factor change, the fact the typical feedback loop in the amp now has something different between channels.
Much more happening than speed of light.... The web sites that preach this simplistic number stuff are vastly oversimplfying! Which for some is ok...
CJA so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping." -
When it comes to this , I'm about as bad as it gets. I measure my wires and they have to be within a 1/16 of an inch or I'm jumping out the window.
When I move stuff , I change the wires. I have a box in the basement all custom made wires of all different lengths. I also keep a spool of Audioquest just in case.
I also will lose sleep at night and get up in the middle of the night just to fix it. I can't have it unequal.Dan
Do I sense a Karma in the making
:biggrin: "....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »Do I sense a Karma in the making
:biggrin:
Very possible as it's getting a bit nutty the amount of wire I own.Dan
Yo Dan!! You of all people should know that different speaker cable lengths don't make a hoot of a difference unless you're over the 1K' mark. I feel your pain though.
"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
You will be fine.Amps- Nakamichi PA 7 & PA 5.
P Amp- Classie Audio. Nakamichi CA 5
Tape- Tandberg 3014A.
Tape- Nakamichi 600.
CD Calif Audio Tercet 3.
CD-Rotel 1078.
Spkrs- Polk Audio RTI 150 Towers.
Spkrs- ADS L1290 Towers.
Spkrs- Yamaha- NS 670,NS 500m,NS 200m, NS 200ma
NS 200ma hybrids.
