Subwoofer - OK on its side?
sban
sban Posts: 1
I just bought a PSW111 powered subwoofer to go in our kitchen on top of the cabinets. Unfortunately, I didn't take the rubber feet into account when I checked if there is enough height available between the top of the cabinets and the ceiling. I could remove the feet, but then the port would be blocked, so I put it on its side. It seems to work fine this way, but I'm wondering if there is any problem in placing it this way?
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2011
    sban wrote: »
    Nope, you're fine. Enjoy.
